How to enable both LAN and wifi on EISY
Edmund Lam
Go to solution Solved by Javi,
Wifi is not available while ethernet is  connected.   Set Wifi credentials from UD Mobile > Settings Tab > WiFi Configuration.
If I enable the Wifi by unhooking the RJ45, will both interfaces be seen by the kernel on subsequent boot?
ifconfig should see 3 lans, lo0 (local), re0 (RJ45) and whatever the Wifi.
I don't believe so,  eisy only has interfaces re0 and wlan0.
While I'm not a network architect, I think you need a VLAN switch, or device that can act like a switch, before connection to eisy.
@Edmund Lam,
What exactly is your use case? The way eisy works is this:
If you have not setup WiFi, then always Ethernet.
If you setup WiFi, then eisy will use WiFi as long as Ethernet cable is not connected.
If you add your own WiFi dongle, then you are on your own because it has never been tested.
The reason we don't use wlan0 is because we are using a Wifi 6 driver in a VM. With your dongle, you will NOT get WiFi 6.
On 2/17/2024 at 9:47 AM, Edmund Lam said:
I want EISY to see my IOT vlan (wifi) and also be on my main lan (wired).
Couldn't that just be accomplished by poking a firewall hole?
I do understand wanting to have PG3x on an IoT VLAN in order for some functionality to work at all because of broadcast domain issues, though I solved that by using my old Polisy as a PG3x head-end in that VLAN, and an above mentioned firewall hole, but you can already slice up the internal NIC to two virtual NICs, so doing VLAN magic seems pretty trivial after that.
Edited by jec6613
  • Thanks 1
      37.8k
      377.4k
