Backlight setting on older Insteon Keypad (2486S/WH6) v.36
2486S/WH6 Keypad v.36
Is this broken or does the device not support changing the backlight setting on the buttons.
I set the on and off to 2/2.   Even 15/7, no change.  Update appears to be done, but no change in illumination.
Edited by Edmund Lam
@Edmund Lam After you make the change you want be sure to hit "Backlight" button to the left of the setting. That should make it adjust. (This was a change made early in IoX 5.x days - back when only the ISY994 was available)
Note there appears to be a longstanding UI issue that when you first open admin console the backlight setting will not display what you have it set to. Do not think this means it will revert to "On 0 / Off 0". The device is set properly, but the UI is not displaying the correct value.  Not sure if this is a bug or just a function of Insteon and how IoX reads (or can't read) the value set at the device level.
