Just installed Yolink hub and a couple devices - purchased PG3x Yolink nodeserver
As the title says I a a new Yolink user, puchased with the intent of linking to my EISY via PG3X.
I installed and set up my Yolink hub with ethernet, and installed a couple of different sensors as test case devices.
I purchased the Yolink nodeserver in the PG3X store and rebooted everything. I do get a node for Yolink:
But this is as far as it goes. I struggled a tiny bit with Wireless Tags in the nodeserver install and realized I had not run "discover". I do not see something similar here. Am I missing something obvious?
Solved by Panda88
You'll need to restart the plugin if you've installed the devices after setting up the hub and connecting it to your eisy. The devices will discover and load then (if that's the case)
you can send me a log file - enable debug please - and I'll see if there is anything
The devices show up separately from the node you show (as stand alone devices)
I had done that, restarted, reinstalled, rebooted everything (well except the Yolink hub) without success. I find it curious that the node is entitled Yolink setup.
I think I will unplug the Yolink hub and see what that produces. Had not contemplated that. Will report back.
Thanks for the immediate response.
Chris
Okay, cold rebooted the Yolink hub, reinstalled the nodeserver, restarted the AC, same result.
Panda88, I also do not show any orphan devices in my device tree that match up with the named missing Yolink devices.
What action shall I take to create the needed debug file?
Edited by glacier991
typos
from the node server click log -then select debug (on right side drop down)
Reboot - wait a little and then select download log - send to me as private message
I replied already - you need to generate UAID and secretKey in the yolink app and copy them to the configuration of the node server
UAID and Secret are in the Yoink app under Settings/Account/Advanced Settings/User Access Credentials. That wasn't obvious to me when I first set up the node server.
Thanks all, especially to Panda88. I followed his advice and everything worked just fine. Landolfi, we both did the same thing apparently. "Advanced settings" did not appear to be a mandatory step... as they often aren't. Here, at least that part of them is.
