How do I access eisy web dashboard?
I just upgraded from the ISY994i to the Eisy Home unit, and all went well.  I'm now learning that I've lost the very simple GUI that the old ISY994i had, which my wife used periodically.  The current interfaces expose way too much info that can get a non-technical person into trouble and mess up the system.
Perhaps one of you guys could package up an App that does what the old ISY994i did and sell it to people who are not technical?  I'm just a lowly hardware engineer with a limited amount of programming knowledge (firmware dev), so it's not something I could do...  Just an idea.
Solved by DNewkirk
Have you looked at the universal devices mobile app? I think that fits what you are describing?
Introducing UD Mobile for iOS - Universal Devices - News (universal-devices.com)
The old AJAX and Home Automation Dashboard local interfaces which were built into IoX on the ISY 994 are still present on the EISY (at least in version 5.7.1).  They have been deprecated and may be removed with any future updates, and some options are not functional (for example, the admin console doesn't seem to open from the UD AJAX interface).  Basic control of devices, scenes, programs and variables seems to work, at least for Insteon devices.
On the EISY, http and https ports have been moved from default 80 and 443 to 8080 and 8443 respectively.  In addition, the mapping of a default web page has been eliminated, so the exact URL to the desired page has to be specified.  They can be accessed at the ip address of the EISY, or alternatively at eisy.local if the EISY is properly registering its name.
EISY Local URLS include:
UD AJAX interface:  http://xxx.xxx.xxx.xxx:8080/WEB/udajax.htm or https://xxx.xxx.xxx.xxx:8443/WEB/udajax.htm
Home Automation Dashboard interface:
http://xxx.xxx.xxx.xxx:8080/WEB/HAD.htm or https://xxx.xxx.xxx.xxx:8443/WEB/HAD.htm
You can also download the appropriate admin console for your version from the EISY at:
https://xxx.xxx.xxx.xxx:8443/WEB/admin.jnlp
or access your local Polyglot server at:
https://xxx.xxx.xxx.xxx:3000
