Home Assistant on eisy not online
I managed to get eisy up and running with something I found online. After eisy is up I was able to get HA running again with the sudo dhclient tap0 sudo dhclient  vm-public Now I just need to be patient and wait to see what @Michel Kohanim's thoughts on how I got it to work.
Link to comment
LOL @Michel Kohanim I'm not a guru it just always works for me :D
@tazman and @rob7419
You don't really need to `dhclient` the `vm-public` nor `tap` devices, those don't need an IP address. Check your rc.conf, there should be no `ifconfig` entries besides these 2:
ifconfig_re0="DHCP"
ifconfig_re0_ipv6="accept_rtadv"
after reboot your `ifconfig -a` should look similar to this (no tap, but vm-bridge is UP):
re0: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
	options=8209b<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,VLAN_HWCSUM,WOL_MAGIC,LINKSTATE>
	ether 00:21:b9:02:5d:7a
	inet6 fe80::221:b9ff:fe02:5d7a%re0 prefixlen 64 scopeid 0x1
	inet6 fd18:31e5:33f2:844e:221:b9ff:fe02:5d7a prefixlen 64 detached autoconf
	inet 10.0.1.152 netmask 0xffffff00 broadcast 10.0.1.255
	media: Ethernet autoselect (1000baseT <full-duplex>)
	status: active
	nd6 options=23<PERFORMNUD,ACCEPT_RTADV,AUTO_LINKLOCAL>
lo0: flags=8049<UP,LOOPBACK,RUNNING,MULTICAST> metric 0 mtu 16384
	options=680003<RXCSUM,TXCSUM,LINKSTATE,RXCSUM_IPV6,TXCSUM_IPV6>
	inet6 ::1 prefixlen 128
	inet6 fe80::1%lo0 prefixlen 64 scopeid 0x2
	inet 127.0.0.1 netmask 0xff000000
	groups: lo
	nd6 options=21<PERFORMNUD,AUTO_LINKLOCAL>
vm-public: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
	ether 52:14:e6:86:b4:2f
	id 00:00:00:00:00:00 priority 32768 hellotime 2 fwddelay 15
	maxage 20 holdcnt 6 proto rstp maxaddr 2000 timeout 1200
	root id 00:00:00:00:00:00 priority 32768 ifcost 0 port 0
	member: re0 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
	        ifmaxaddr 0 port 1 priority 128 path cost 20000
	groups: bridge vm-switch viid-4c918@
	nd6 options=9<PERFORMNUD,IFDISABLED>
Start the VM (`sudo vm start homeassistant`) your `ifconfig -a` output should become like this:
	options=82099<RXCSUM,VLAN_MTU,VLAN_HWTAGGING,VLAN_HWCSUM,WOL_MAGIC,LINKSTATE>
	status: active
	groups: lo
	member: tap0 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
	        ifmaxaddr 0 port 4 priority 128 path cost 2000000
tap0: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
	description: vmnet/homeassistant/0/public
	options=80000<LINKSTATE>
	ether 58:9c:fc:10:f8:32
	groups: tap vm-port
	status: active
	nd6 options=29<PERFORMNUD,IFDISABLED,AUTO_LINKLOCAL>
	Opened by PID 5537
`vm-public` has 2 ports `re0` and `tap0` and all interfaces are `UP`
You should be able to see traffic on `tap0` interface, for example something like this:
# just dump on the screen
sudo tcpdump -i tap0 -s0 -vvv
# save a .pcap file
sudo tcpdump -i tap0 -s0 -w trace1.pcap
see if you can capture a minute or two of traffic and attach what you have (or PM me).
For the reference - I'm using pfSense 23.09.1-RELEASE as a router with KEA as DHCP server selected.
Link to comment
ifconfig_re0="DHCP"
The dhclient was just a way I found to make the vm come online.
ifconfig_re0="DHCP"
ifconfig_re0_ipv6="inet6 accept_rtadv"
Was already in mine and I placed # in front of the home assistant so it would not start automatically.
	status: active
	groups: lo
 After restart
[admin@eisy ~]$ sudo ifconfig -a
Password:
        ether 00:21:b9:02:61:da
        inet6 fe80::221:b9ff:fe02:61da%re0 prefixlen 64 scopeid 0x1
        inet6 2601:500:8801:38a0:221:b9ff:fe02:61da prefixlen 64 autoconf
        inet 10.0.0.66 netmask 0xffffff00 broadcast 10.0.0.255
        status: active
        groups: lo
        ether 96:f8:51:04:43:ae
Password:
        status: active
        groups: lo
	status: active
	groups: lo
	groups: tap vm-port
	status: active
	Opened by PID 5537
        status: active
        groups: lo
vm-public: flags=8802<BROADCAST,SIMPLEX,MULTICAST> metric 0 mtu 1500
tap0: flags=8942<BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
        ether 58:9c:fc:10:90:31
        groups: tap vm-port
        status: active
        Opened by PID 8050
 After starting home assistant and showing running under vm list but is not available at homeassistant.local:8123 where I find it when it is running.
        status: active
        groups: lo
        groups: tap vm-port
        status: active
        Opened by PID 8050
# save a .pcap file
[admin@eisy ~]$ sudo tcpdump -i tap0 -s0 -vvv
tcpdump: listening on tap0, link-type EN10MB (Ethernet), capture size 262144 bytes
 Since home assistant is not running there is no traffic.
Link to comment
So what happens if after you bring the home assistant you do this
sudo ifconfig vm-public up; sudo ifconfig tap0 up
Also try adding this into `/etc/sysctl.conf` and reboot
net.link.tap.up_on_open=1
Link to comment
@xKingthat brought it up! Now will that carry over on reboot or is there something we need to add somewhere?
Link to comment
Added
25 minutes ago, xKing said:
Stop home assistant, reboot eisy, do check this
sysctl -a | grep net.link.tap.up_on_open
Output
[admin@eisy ~]$ sysctl -a | grep net.link.tap.up_on_open
net.link.tap.up_on_open: 1
But if I try to enable vm_list="homeassistant" in rc.conf the virtual switches are not UP any more.
Link to comment
On 3/9/2024 at 1:07 PM, KSaccullo01 said:
Restart HA as a CRON job. Have CRON wait 3 minutes before starting HA.
@xKingthis was a suggestion that might help now?
Edited by tazman
Link to comment
###MAINTAINED BY UDX####
###DO NOT MODIFY###
hostname="eisy"
# Set dumpdev to "AUTO" to enable crash dumps, "NO" to disable
dumpdev="NO"
zfs_enable="YES"
dbus_enable="YES"
sshd_enable="YES"
moused_nondefault_enable="NO"
sendmail_submit_enable="NO"
sendmail_outbound_enable="NO"
sendmail_msp_queue_enable="NO"
clear_tmp_enable="YES"
#NTP
ntpd_enable="YES"
ntpd_sync_on_start="YES"
#HDMI is disabled by default
#kld_list="i915kms"
#Make sure dhclient is run in the background
background_dhclient="YES"
#make sure we support double stack
ipv6_ipv4mapping="YES"
defaultroute_delay="0"
#Network Interfaces (default)
rtsold_enable="YES"
#for now, do not let iwlwifi/iwm get loaded
devmatch_enable="YES"
devmatch_blocklist="if_iwm if_iwlwifi"
UDX_UPGRADE_STATUS="active"
ifconfig_re0="DHCP"
vm_enable="YES"
vm_dir="zfs:storage/vms"
mdnsresponderposix_flags="-f /usr/local/etc/udx.d/static/mdns.services"
Link to comment
Ok, try commenting out just `vm_list` from `/etc/rc.conf` and comment out the line you put in `/etc/sysctl.conf`
reboot and see what does the `sysctl -a | grep up_on_open`  say?
you also have a duplicate ifconfig_re0_ipv6 in /etc/rc.conf - please delete the second one
Link to comment
@xKingthe lines are a little different which one should go?
With the 'vm_list' out and '/etc/sysctl.conf' line out
[admin@eisy ~]$ sysctl -a | grep up_on_open
Link to comment
@xKingattached is my homeassistant.conf file is there any other VM configuration you know of?
loader="uefi"
cpu="2"
memory="2G"
network0_type="virtio-net"
network0_switch="public"
disk0_name="disk0"
disk0_dev="sparse-zvol"
disk0_type="virtio-blk"
uuid="EDIT"
network0_mac="EDIT"
#graphics="yes"
#graphics_wait="yes"
Link to comment
That looks fine, so what happens if you do `sudo vm start homeassistant` now - would tap0 still come up with no “UP” flag and require `sudo ifconfig tap0 up` ?
Delete this:
Link to comment
@xKingfor this instance everything started fine Tap0 is UP and home assistant became available at homeassistant.local:8123 but I don't know that it would happen all the time unless it is just a matter of starting HA after everything else.
Link to comment
Just to clarify - when you say you restarted and interfaces were not up - do you mean that you have vm_list=“homeassistant” uncommented? Or you booted and did `vm start homeassistant` manually?
Link to comment
