Home Assistant on eisy not online
Interface `tap0` should come UP if this thing is set to 1.
net.link.tap.up_on_open: 1
It’s done by the `vm init` which is called if you have `vm_enable=YES` in /etc/rc.conf
Or you can do that manually by running `sudo vm init` before you do `sudo vm start`
See if you can do a couple reboots and just check `sysctl -a | grep up_on_open` after reboot - you always see 1 ?
[admin@eisy ~]$ sysctl -a | grep up_on_open
[admin@eisy ~]$ sudo ifconfig -a
Password:
re0: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
        options=82099<RXCSUM,VLAN_MTU,VLAN_HWTAGGING,VLAN_HWCSUM,WOL_MAGIC,LINKSTATE>
        ether 00:21:b9:02:61:da
        inet6 fe80::221:b9ff:fe02:61da%re0 prefixlen 64 scopeid 0x1
        inet6 2601:500:8801:38a0:221:b9ff:fe02:61da prefixlen 64 autoconf
        inet 10.0.0.66 netmask 0xffffff00 broadcast 10.0.0.255
        media: Ethernet autoselect (1000baseT <full-duplex>)
        status: active
        nd6 options=23<PERFORMNUD,ACCEPT_RTADV,AUTO_LINKLOCAL>
lo0: flags=8049<UP,LOOPBACK,RUNNING,MULTICAST> metric 0 mtu 16384
        options=680003<RXCSUM,TXCSUM,LINKSTATE,RXCSUM_IPV6,TXCSUM_IPV6>
        inet6 ::1 prefixlen 128
        inet6 fe80::1%lo0 prefixlen 64 scopeid 0x2
        inet 127.0.0.1 netmask 0xff000000
        groups: lo
        nd6 options=21<PERFORMNUD,AUTO_LINKLOCAL>
vm-public: flags=8802<BROADCAST,SIMPLEX,MULTICAST> metric 0 mtu 1500
        ether 9e:73:5c:44:25:33
        id 00:00:00:00:00:00 priority 32768 hellotime 2 fwddelay 15
        maxage 20 holdcnt 6 proto rstp maxaddr 2000 timeout 1200
        root id 00:00:00:00:00:00 priority 32768 ifcost 0 port 0
        member: tap0 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
                ifmaxaddr 0 port 4 priority 128 path cost 2000000
        member: re0 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
                ifmaxaddr 0 port 1 priority 128 path cost 20000
        groups: bridge vm-switch viid-4c918@
        nd6 options=9<PERFORMNUD,IFDISABLED>
tap0: flags=8942<BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
        description: vmnet/homeassistant/0/public
        options=80000<LINKSTATE>
        ether 58:9c:fc:10:90:31
        groups: tap vm-port
        status: active
        nd6 options=29<PERFORMNUD,IFDISABLED,AUTO_LINKLOCAL>
        Opened by PID 6388
@xKingI will do a couple of reboots but this is the state it was in when HA did not come online after the last reboot. It seems odd to have the 1 but the devices not to be 'UP'
Start 1 everything good and HA started
Start 2 '1' and vm-public UP at reboot HA would not come up and vm-public and Tap0 not up after starting HA
Start 3 '1' and vm-public UP at reboot HA started noticed pattern from before did 'sudo vm poweroff -f homeassistant' then rebooted
Start 4 '1' and vm-public UP at reboot HA would not come up and vm-public and Tap0 not up after starting HA
Start 5 '1' and vm-public UP at reboot HA started moved vm_dir="zfs:storage/vms" to before vm_enable="YES" in rc.conf file
Start 6 '1' and vm-public UP at reboot then HA started
Start 7 '1' and vm-public UP at reboot then HA started
Start 8 '1' and vm-public UP HA did not work
Start 9 '1' and vm-public UP at reboot HA started
Start 10 '1' and vm-public UP at reboot HA started
@xKingI feel moving the path of vm before starting vm helped but I can test more tomorrow afternoon if you want more restarts or to try something else.
Sorry if I was not specific but please watch the `tap0` status. Just 2-3 reboots is ok :)
net.link.tap.up_on_open - is the system variable that says - bring the tap interface UP as soon as there is an opener (VM starts).
@xKing and @tazman
xKing, I would like to also express my appreciation on your "Guru" assistance. And here is what I have so far:
20 hours ago, xKing said:
For the reference - I'm using pfSense 23.09.1-RELEASE as a router with KEA as DHCP server selected.
I also am on pfSense 23.09.1 RELEASE, but still using ISC DHCP server, haven't switched to KEA due to it not being fully implemented. Was going to switch when it became the default. I might attempt to switch to KEA and see if it make a difference but will have to wait till later this afternoon to try.
After reading through all the post, the only thing that I changed to start with is in the /etc/rc.conf file:
Quote
ifconfig_re0_ipv6="inet6 accept_rtadv"
to
ifconfig_re0_ipv6="accept_rtadv"
Didn't make a difference in how the Home Assistant VM started, VM was running but not connect to the network.
I then commented out in /etc/rc.conf
Quote
#vm_list="homeassistant"
Performed 4 consecutive reboots with the following steps.
  1. $ ifconfig -a - to check if vm-public was "UP" and in all 4 reboots it was true.
  2. $ sysctl -a | grep net.link.tap.up_on_open - check if net.link.tap.up_on_open: was = "1", all 4 reboots it was true.
  3. $ sudo vm start homeassistant - in all 4 cases the VM started successfully, the tap0 interface was created with a status of "UP" and connected to the network.
Then I uncomment the "vm_list" line above to set /etc/rc.conf back the the original for the VM to start during boot. Again performed 4 consecutive reboots, VM was running but none of the reboots was it able to connect to the network on the initial boot sequence. Check the following on each:
  1. $ ifconfig -a - to check if vm-public and tap0 was "UP" and in all 4 reboots it was false. Neither interface showed "UP" status, on reboots 2 & 4 waited about 3 minute and then
    Quote
    sudo ifconfig vm-public up; sudo ifconfig tap0 up
      and the VM immediately started replying to ping request.
In all the reboots, this variable was always set to "1".
When does this variable get set during the boot sequence? Is it possible that the VM is starting before it does and prevents the network from being established?
Still working on tcpdump packet captures. Will DM them when I get something worth sending, will try to capture from pfSense first and then from the eisy.
And finally my /etc/rc.conf and VM configure files for you to review:
rc_conf 03-11-2024.txt HA_VM_Configure 03-11-2024.txt
Edited by rob7419
@rob7419 thank you sir, can you try adding net.link.tap.up_on_open=1 at the bottom of /boot/loader.conf
This should set it as early as possible during the boot sequence.
Added to /boot/loader.conf - net.link.tap.up_on_open=1
Quote
[admin@eisy ~]$ cat /boot/loader.conf
kern.geom.label.disk_ident.enable="0"
kern.geom.label.gptid.enable="0"
cryptodev_load="YES"
zfs_load="YES"
tpm_load="YES"
coretemp_load=YES
autoboot_delay="0"
kern.cam.boot_delay="1000"
beastie_disable="YES"
[admin@eisy ~]$
no change and just in case
Quote
net.link.tap.up_on_open="1"
still no change.
In both cases
Quote
Brought the Home Assistant VM network back online.
@xKingI think it is safe to say net.link.tap.up_on_open: 1 and vm-public is UP at start are being set correctly but unlike @rob7419 I have experienced starting HA manually still results in a fail and vm-public and Tap0 are not showing as UP after starting HA but sudo ifconfig vm-public up; sudo ifconfig tap0 up sets them to UP and HA starts working.
Allright, remove that line from loader.conf and add these (just for the TEST) to /etc/rc.conf
Reboot and see if homeassistant still has an issue?
udx_enable="NO"
isy_enable="NO"
@xKingrebooted 3 times and HA came right up
###MAINTAINED BY UDX####
###DO NOT MODIFY###
hostname="eisy"
# Set dumpdev to "AUTO" to enable crash dumps, "NO" to disable
dumpdev="NO"
zfs_enable="YES"
dbus_enable="YES"
sshd_enable="YES"
moused_nondefault_enable="NO"
sendmail_submit_enable="NO"
sendmail_outbound_enable="NO"
sendmail_msp_queue_enable="NO"
clear_tmp_enable="YES"
udx_enable="NO"
isy_enable="NO"
#NTP
ntpd_enable="YES"
ntpd_sync_on_start="YES"
#HDMI is disabled by default
#kld_list="i915kms"
#Make sure dhclient is run in the background
background_dhclient="YES"
#make sure we support double stack
ipv6_ipv4mapping="YES"
defaultroute_delay="0"
#Network Interfaces (default)
rtsold_enable="YES"
#for now, do not let iwlwifi/iwm get loaded
devmatch_enable="YES"
devmatch_blocklist="if_iwm if_iwlwifi"
UDX_UPGRADE_STATUS="active"
ifconfig_re0="DHCP"
#ifconfig_re0_ipv6="inet6 accept_rtadv"
vm_enable="YES"
#vm_dir="zfs:storage/vms"
mdnsresponderposix_flags="-f /usr/local/etc/udx.d/static/mdns.services"
udx_enable="NO"
isy_enable="NO"
Me too, 3 successfully reboots with HA VM connecting to the network.
Thanks! Time to ask @Michel Kohanim what kind of shady business is he up to in those scripts.
There is a fun thing to do - reboot with UDX and ISY disabled and do
dmesg
look at last lines where interfaces go UP/DOWN
now re-enable UDX and ISY - reboot again and just do dmesg command again - see more UP/DOWN stuff?
dmesg
This is the end of the file without ISY and UDX
WARNING: attempt to domain_add(bluetooth) after domainfinalize()
WARNING: attempt to domain_add(netgraph) after domainfinalize()
bridge0: Ethernet address: EDITED
bridge0: changing name to 'vm-public'
re0: promiscuous mode enabled
vm-public: link state changed to UP
Security policy loaded: MAC/ntpd (mac_ntpd)
tap0: Ethernet address: EDITED
tap0: promiscuous mode enabled
re0: link state changed to DOWN
vm-public: link state changed to DOWN
tap0: link state changed to UP
re0: link state changed to UP
This is ISY and UDX enabled then reboot and HA not working
lo0: link state changed to DOWN
lo0: link state changed to UP
I have both full files saved if they are needed.
10 minutes ago, Michel Kohanim said:
Is anyone using WiFi?
I am not using WIFI.
dmesg
Just to verify that I'm getting the simular results as @tazman
UDX & ISY Disabled, HA VM connects to network
Quote
Trying to mount root from zfs:zudi/ROOT/default []...
uhub0: 14 ports with 14 removable, self powered
Root mount waiting for: usbus0 CAM
ugen0.2: <vendor 0x8087 product 0x0026> at usbus0
ubt0 on uhub0
ubt0: <vendor 0x8087 product 0x0026, class 224/1, rev 2.01/0.02, addr 1> on usbus0
bridge0: Ethernet address: 58:9c:fc:**:**:**
tap0: Ethernet address: 58:9c:fc:**:**:**
UDX & ISY Enabled, HA VM will not connect to network, last couple of lines on mine are different
Quote
ubt0 on uhub0
tap0: link state changed to DOWN
Waiting (max 60 seconds) for system process `vnlru' to stop... done
Waiting (max 60 seconds) for system process `syncer' to stop...
Syncing disks, vnodes remaining... 0 0 0 0 0 0 done
All buffers synced.
I am on a wired connection.
It's very odd. We do use tap0 for Wifi. ISY has no permissions to do anything with the hardware/networking. If you have ever attempted to use wifi, please do this:
sudo udxops.sh wifi.reset
Also, please do make sure in /etc/rc.conf:
ifconfig_inet6="inet6 accept_rtadv" (you need the inet6 in there.
This is the dmesg -a output with both UDX & ISY enabled and #vm_list="homeassistant" disabled in /etc/rc.conf, once eisy boots, start the HA VM.
Quote
ubt0 on uhub0
*** sudo vm start homeassistant *** addition to dmesg -a once HA VM is started and successfully connects to network
The interfaces do not produce the same behavior when started separately.
Reset the Wifi, I've never set up the WIFI, but just to make sure this wasn't the issue. HA VM went offline when $ sudo udxops.sh wifi.reset was entered.
Updated back to:  ifconfig_inet6="inet6 accept_rtadv" in /etc/rc.conf and enabled the vm_list="homeassistant" to enabled VM to start on boot.
Rebooted eisy, dmesg -a output with same results that HA VM starts but does not connect to the network.
Quote
ubt0 on uhub0
No change in boot with WiFi reset.
To bad I had high hopes my eisy started out as WIFI but I did the 4 button press to reset when we found the problem with some node servers and WIFI. I will still give it a try tonight when I get home.
40 minutes ago, Michel Kohanim said:
Please send me
/var/udx/logs/debug.log
Sent them to support@universal-devices.com
@rob7419thanks for the update I sent Michel a message through my ticket because I was not able to figure out how to access the file he wanted.
On 3/8/2024 at 5:57 PM, rob7419 said:
@Michel Kohanim
I am not able to get to any other CLI session other then the HA CLI through the VNC viewer.
FYI, to get out of "ha" prompt and down to real OS you can run "login".  That will drop you to a proper linux prompt in the HA OS.
      37.1k
      371.5k
