tazman Posted March 9 Author Share Posted March 9 I managed to get eisy up and running with something I found online. After eisy is up I was able to get HA running again with the sudo dhclient tap0 sudo dhclient vm-public Now I just need to be patient and wait to see what @Michel Kohanim's thoughts on how I got it to work. Quote Link to comment
KSaccullo01 Posted March 9 Share Posted March 9 Restart HA as a CRON job. Have CRON wait 3 minutes before starting HA. Quote Link to comment
Michel Kohanim Posted March 10 Share Posted March 10 @tazman and @rob7419, The guru himself is working on it. I shall keep you all posted. With kind regards, Michel 1 Quote Link to comment
xKing Posted March 10 Share Posted March 10 LOL @Michel Kohanim I'm not a guru it just always works for me @tazman and @rob7419 You don't really need to `dhclient` the `vm-public` nor `tap` devices, those don't need an IP address. Check your rc.conf, there should be no `ifconfig` entries besides these 2: ifconfig_re0="DHCP" ifconfig_re0_ipv6="accept_rtadv" after reboot your `ifconfig -a` should look similar to this (no tap, but vm-bridge is UP): re0: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500 options=8209b<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,VLAN_HWCSUM,WOL_MAGIC,LINKSTATE> ether 00:21:b9:02:5d:7a inet6 fe80::221:b9ff:fe02:5d7a%re0 prefixlen 64 scopeid 0x1 inet6 fd18:31e5:33f2:844e:221:b9ff:fe02:5d7a prefixlen 64 detached autoconf inet 10.0.1.152 netmask 0xffffff00 broadcast 10.0.1.255 media: Ethernet autoselect (1000baseT <full-duplex>) status: active nd6 options=23<PERFORMNUD,ACCEPT_RTADV,AUTO_LINKLOCAL> lo0: flags=8049<UP,LOOPBACK,RUNNING,MULTICAST> metric 0 mtu 16384 options=680003<RXCSUM,TXCSUM,LINKSTATE,RXCSUM_IPV6,TXCSUM_IPV6> inet6 ::1 prefixlen 128 inet6 fe80::1%lo0 prefixlen 64 scopeid 0x2 inet 127.0.0.1 netmask 0xff000000 groups: lo nd6 options=21<PERFORMNUD,AUTO_LINKLOCAL> vm-public: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500 ether 52:14:e6:86:b4:2f id 00:00:00:00:00:00 priority 32768 hellotime 2 fwddelay 15 maxage 20 holdcnt 6 proto rstp maxaddr 2000 timeout 1200 root id 00:00:00:00:00:00 priority 32768 ifcost 0 port 0 member: re0 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP> ifmaxaddr 0 port 1 priority 128 path cost 20000 groups: bridge vm-switch viid-4c918@ nd6 options=9<PERFORMNUD,IFDISABLED> Start the VM (`sudo vm start homeassistant`) your `ifconfig -a` output should become like this: re0: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500 options=82099<RXCSUM,VLAN_MTU,VLAN_HWTAGGING,VLAN_HWCSUM,WOL_MAGIC,LINKSTATE> ether 00:21:b9:02:5d:7a inet6 fe80::221:b9ff:fe02:5d7a%re0 prefixlen 64 scopeid 0x1 inet6 fd18:31e5:33f2:844e:221:b9ff:fe02:5d7a prefixlen 64 detached autoconf inet 10.0.1.152 netmask 0xffffff00 broadcast 10.0.1.255 media: Ethernet autoselect (1000baseT <full-duplex>) status: active nd6 options=23<PERFORMNUD,ACCEPT_RTADV,AUTO_LINKLOCAL> lo0: flags=8049<UP,LOOPBACK,RUNNING,MULTICAST> metric 0 mtu 16384 options=680003<RXCSUM,TXCSUM,LINKSTATE,RXCSUM_IPV6,TXCSUM_IPV6> inet6 ::1 prefixlen 128 inet6 fe80::1%lo0 prefixlen 64 scopeid 0x2 inet 127.0.0.1 netmask 0xff000000 groups: lo nd6 options=21<PERFORMNUD,AUTO_LINKLOCAL> vm-public: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500 ether 52:14:e6:86:b4:2f id 00:00:00:00:00:00 priority 32768 hellotime 2 fwddelay 15 maxage 20 holdcnt 6 proto rstp maxaddr 2000 timeout 1200 root id 00:00:00:00:00:00 priority 32768 ifcost 0 port 0 member: tap0 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP> ifmaxaddr 0 port 4 priority 128 path cost 2000000 member: re0 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP> ifmaxaddr 0 port 1 priority 128 path cost 20000 groups: bridge vm-switch viid-4c918@ nd6 options=9<PERFORMNUD,IFDISABLED> tap0: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500 description: vmnet/homeassistant/0/public options=80000<LINKSTATE> ether 58:9c:fc:10:f8:32 groups: tap vm-port media: Ethernet autoselect status: active nd6 options=29<PERFORMNUD,IFDISABLED,AUTO_LINKLOCAL> Opened by PID 5537 `vm-public` has 2 ports `re0` and `tap0` and all interfaces are `UP` You should be able to see traffic on `tap0` interface, for example something like this: # just dump on the screen sudo tcpdump -i tap0 -s0 -vvv # save a .pcap file sudo tcpdump -i tap0 -s0 -w trace1.pcap see if you can capture a minute or two of traffic and attach what you have (or PM me). For the reference - I'm using pfSense 23.09.1-RELEASE as a router with KEA as DHCP server selected. Quote Link to comment
tazman Posted March 10 Author Share Posted March 10 11 minutes ago, xKing said: LOL @Michel Kohanim I'm not a guru it just always works for me @tazman and @rob7419 You don't really need to `dhclient` the `vm-public` nor `tap` devices, those don't need an IP address. Check your rc.conf, there should be no `ifconfig` entries besides these 2: ifconfig_re0="DHCP" ifconfig_re0_ipv6="accept_rtadv" The dhclient was just a way I found to make the vm come online. ifconfig_re0="DHCP" ifconfig_re0_ipv6="inet6 accept_rtadv" Was already in mine and I placed # in front of the home assistant so it would not start automatically. 11 minutes ago, xKing said: after reboot your `ifconfig -a` should look similar to this (no tap, but vm-bridge is UP): re0: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500 options=8209b<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,VLAN_HWCSUM,WOL_MAGIC,LINKSTATE> ether 00:21:b9:02:5d:7a inet6 fe80::221:b9ff:fe02:5d7a%re0 prefixlen 64 scopeid 0x1 inet6 fd18:31e5:33f2:844e:221:b9ff:fe02:5d7a prefixlen 64 detached autoconf inet 10.0.1.152 netmask 0xffffff00 broadcast 10.0.1.255 media: Ethernet autoselect (1000baseT <full-duplex>) status: active nd6 options=23<PERFORMNUD,ACCEPT_RTADV,AUTO_LINKLOCAL> lo0: flags=8049<UP,LOOPBACK,RUNNING,MULTICAST> metric 0 mtu 16384 options=680003<RXCSUM,TXCSUM,LINKSTATE,RXCSUM_IPV6,TXCSUM_IPV6> inet6 ::1 prefixlen 128 inet6 fe80::1%lo0 prefixlen 64 scopeid 0x2 inet 127.0.0.1 netmask 0xff000000 groups: lo nd6 options=21<PERFORMNUD,AUTO_LINKLOCAL> vm-public: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500 ether 52:14:e6:86:b4:2f id 00:00:00:00:00:00 priority 32768 hellotime 2 fwddelay 15 maxage 20 holdcnt 6 proto rstp maxaddr 2000 timeout 1200 root id 00:00:00:00:00:00 priority 32768 ifcost 0 port 0 member: re0 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP> ifmaxaddr 0 port 1 priority 128 path cost 20000 groups: bridge vm-switch viid-4c918@ nd6 options=9<PERFORMNUD,IFDISABLED> After restart [admin@eisy ~]$ sudo ifconfig -a Password: re0: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500 options=8209b<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,VLAN_HWCSUM,WOL_MAGIC,LINKSTATE> ether 00:21:b9:02:61:da inet6 fe80::221:b9ff:fe02:61da%re0 prefixlen 64 scopeid 0x1 inet6 2601:500:8801:38a0:221:b9ff:fe02:61da prefixlen 64 autoconf inet 10.0.0.66 netmask 0xffffff00 broadcast 10.0.0.255 media: Ethernet autoselect (1000baseT <full-duplex>) status: active nd6 options=23<PERFORMNUD,ACCEPT_RTADV,AUTO_LINKLOCAL> lo0: flags=8049<UP,LOOPBACK,RUNNING,MULTICAST> metric 0 mtu 16384 options=680003<RXCSUM,TXCSUM,LINKSTATE,RXCSUM_IPV6,TXCSUM_IPV6> inet6 ::1 prefixlen 128 inet6 fe80::1%lo0 prefixlen 64 scopeid 0x2 inet 127.0.0.1 netmask 0xff000000 groups: lo nd6 options=21<PERFORMNUD,AUTO_LINKLOCAL> vm-public: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500 ether 96:f8:51:04:43:ae id 00:00:00:00:00:00 priority 32768 hellotime 2 fwddelay 15 maxage 20 holdcnt 6 proto rstp maxaddr 2000 timeout 1200 root id 00:00:00:00:00:00 priority 32768 ifcost 0 port 0 member: re0 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP> ifmaxaddr 0 port 1 priority 128 path cost 20000 groups: bridge vm-switch viid-4c918@ nd6 options=9<PERFORMNUD,IFDISABLED> 11 minutes ago, xKing said: [admin@eisy ~]$ sudo ifconfig -a Password: re0: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500 options=8209b<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,VLAN_HWCSUM,WOL_MAGIC,LINKSTATE> ether 00:21:b9:02:61:da inet6 fe80::221:b9ff:fe02:61da%re0 prefixlen 64 scopeid 0x1 inet6 2601:500:8801:38a0:221:b9ff:fe02:61da prefixlen 64 autoconf inet 10.0.0.66 netmask 0xffffff00 broadcast 10.0.0.255 media: Ethernet autoselect (1000baseT <full-duplex>) status: active nd6 options=23<PERFORMNUD,ACCEPT_RTADV,AUTO_LINKLOCAL> lo0: flags=8049<UP,LOOPBACK,RUNNING,MULTICAST> metric 0 mtu 16384 options=680003<RXCSUM,TXCSUM,LINKSTATE,RXCSUM_IPV6,TXCSUM_IPV6> inet6 ::1 prefixlen 128 inet6 fe80::1%lo0 prefixlen 64 scopeid 0x2 inet 127.0.0.1 netmask 0xff000000 groups: lo nd6 options=21<PERFORMNUD,AUTO_LINKLOCAL> vm-public: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500 ether 96:f8:51:04:43:ae id 00:00:00:00:00:00 priority 32768 hellotime 2 fwddelay 15 maxage 20 holdcnt 6 proto rstp maxaddr 2000 timeout 1200 root id 00:00:00:00:00:00 priority 32768 ifcost 0 port 0 member: re0 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP> ifmaxaddr 0 port 1 priority 128 path cost 20000 groups: bridge vm-switch viid-4c918@ nd6 options=9<PERFORMNUD,IFDISABLED> Start the VM (`sudo vm start homeassistant`) your `ifconfig -a` output should become like this: re0: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500 options=82099<RXCSUM,VLAN_MTU,VLAN_HWTAGGING,VLAN_HWCSUM,WOL_MAGIC,LINKSTATE> ether 00:21:b9:02:5d:7a inet6 fe80::221:b9ff:fe02:5d7a%re0 prefixlen 64 scopeid 0x1 inet6 fd18:31e5:33f2:844e:221:b9ff:fe02:5d7a prefixlen 64 detached autoconf inet 10.0.1.152 netmask 0xffffff00 broadcast 10.0.1.255 media: Ethernet autoselect (1000baseT <full-duplex>) status: active nd6 options=23<PERFORMNUD,ACCEPT_RTADV,AUTO_LINKLOCAL> lo0: flags=8049<UP,LOOPBACK,RUNNING,MULTICAST> metric 0 mtu 16384 options=680003<RXCSUM,TXCSUM,LINKSTATE,RXCSUM_IPV6,TXCSUM_IPV6> inet6 ::1 prefixlen 128 inet6 fe80::1%lo0 prefixlen 64 scopeid 0x2 inet 127.0.0.1 netmask 0xff000000 groups: lo nd6 options=21<PERFORMNUD,AUTO_LINKLOCAL> vm-public: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500 ether 52:14:e6:86:b4:2f id 00:00:00:00:00:00 priority 32768 hellotime 2 fwddelay 15 maxage 20 holdcnt 6 proto rstp maxaddr 2000 timeout 1200 root id 00:00:00:00:00:00 priority 32768 ifcost 0 port 0 member: tap0 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP> ifmaxaddr 0 port 4 priority 128 path cost 2000000 member: re0 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP> ifmaxaddr 0 port 1 priority 128 path cost 20000 groups: bridge vm-switch viid-4c918@ nd6 options=9<PERFORMNUD,IFDISABLED> tap0: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500 description: vmnet/homeassistant/0/public options=80000<LINKSTATE> ether 58:9c:fc:10:f8:32 groups: tap vm-port media: Ethernet autoselect status: active nd6 options=29<PERFORMNUD,IFDISABLED,AUTO_LINKLOCAL> Opened by PID 5537 `vm-public` has 2 ports `re0` and `tap0` and all interfaces are `UP` [admin@eisy ~]$ sudo ifconfig -a re0: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500 options=82099<RXCSUM,VLAN_MTU,VLAN_HWTAGGING,VLAN_HWCSUM,WOL_MAGIC,LINKSTATE> ether 00:21:b9:02:61:da inet6 fe80::221:b9ff:fe02:61da%re0 prefixlen 64 scopeid 0x1 inet6 2601:500:8801:38a0:221:b9ff:fe02:61da prefixlen 64 autoconf inet 10.0.0.66 netmask 0xffffff00 broadcast 10.0.0.255 media: Ethernet autoselect (1000baseT <full-duplex>) status: active nd6 options=23<PERFORMNUD,ACCEPT_RTADV,AUTO_LINKLOCAL> lo0: flags=8049<UP,LOOPBACK,RUNNING,MULTICAST> metric 0 mtu 16384 options=680003<RXCSUM,TXCSUM,LINKSTATE,RXCSUM_IPV6,TXCSUM_IPV6> inet6 ::1 prefixlen 128 inet6 fe80::1%lo0 prefixlen 64 scopeid 0x2 inet 127.0.0.1 netmask 0xff000000 groups: lo nd6 options=21<PERFORMNUD,AUTO_LINKLOCAL> vm-public: flags=8802<BROADCAST,SIMPLEX,MULTICAST> metric 0 mtu 1500 ether 96:f8:51:04:43:ae id 00:00:00:00:00:00 priority 32768 hellotime 2 fwddelay 15 maxage 20 holdcnt 6 proto rstp maxaddr 2000 timeout 1200 root id 00:00:00:00:00:00 priority 32768 ifcost 0 port 0 member: tap0 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP> ifmaxaddr 0 port 4 priority 128 path cost 2000000 member: re0 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP> ifmaxaddr 0 port 1 priority 128 path cost 20000 groups: bridge vm-switch viid-4c918@ nd6 options=9<PERFORMNUD,IFDISABLED> tap0: flags=8942<BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500 description: vmnet/homeassistant/0/public options=80000<LINKSTATE> ether 58:9c:fc:10:90:31 groups: tap vm-port media: Ethernet autoselect status: active nd6 options=29<PERFORMNUD,IFDISABLED,AUTO_LINKLOCAL> Opened by PID 8050 After starting home assistant and showing running under vm list but is not available at homeassistant.local:8123 where I find it when it is running. [admin@eisy ~]$ sudo ifconfig -a re0: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500 options=82099<RXCSUM,VLAN_MTU,VLAN_HWTAGGING,VLAN_HWCSUM,WOL_MAGIC,LINKSTATE> ether 00:21:b9:02:61:da inet6 fe80::221:b9ff:fe02:61da%re0 prefixlen 64 scopeid 0x1 inet6 2601:500:8801:38a0:221:b9ff:fe02:61da prefixlen 64 autoconf inet 10.0.0.66 netmask 0xffffff00 broadcast 10.0.0.255 media: Ethernet autoselect (1000baseT <full-duplex>) status: active nd6 options=23<PERFORMNUD,ACCEPT_RTADV,AUTO_LINKLOCAL> lo0: flags=8049<UP,LOOPBACK,RUNNING,MULTICAST> metric 0 mtu 16384 options=680003<RXCSUM,TXCSUM,LINKSTATE,RXCSUM_IPV6,TXCSUM_IPV6> inet6 ::1 prefixlen 128 inet6 fe80::1%lo0 prefixlen 64 scopeid 0x2 inet 127.0.0.1 netmask 0xff000000 groups: lo nd6 options=21<PERFORMNUD,AUTO_LINKLOCAL> vm-public: flags=8802<BROADCAST,SIMPLEX,MULTICAST> metric 0 mtu 1500 ether 96:f8:51:04:43:ae id 00:00:00:00:00:00 priority 32768 hellotime 2 fwddelay 15 maxage 20 holdcnt 6 proto rstp maxaddr 2000 timeout 1200 root id 00:00:00:00:00:00 priority 32768 ifcost 0 port 0 member: tap0 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP> ifmaxaddr 0 port 4 priority 128 path cost 2000000 member: re0 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP> ifmaxaddr 0 port 1 priority 128 path cost 20000 groups: bridge vm-switch viid-4c918@ nd6 options=9<PERFORMNUD,IFDISABLED> tap0: flags=8942<BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500 description: vmnet/homeassistant/0/public options=80000<LINKSTATE> ether 58:9c:fc:10:90:31 groups: tap vm-port media: Ethernet autoselect status: active nd6 options=29<PERFORMNUD,IFDISABLED,AUTO_LINKLOCAL> Opened by PID 8050 11 minutes ago, xKing said: You should be able to see traffic on `tap0` interface, for example something like this: # just dump on the screen sudo tcpdump -i tap0 -s0 -vvv # save a .pcap file sudo tcpdump -i tap0 -s0 -w trace1.pcap see if you can capture a minute or two of traffic and attach what you have (or PM me). For the reference - I'm using pfSense 23.09.1-RELEASE as a router with KEA as DHCP server selected. [admin@eisy ~]$ sudo tcpdump -i tap0 -s0 -vvv tcpdump: listening on tap0, link-type EN10MB (Ethernet), capture size 262144 bytes Since home assistant is not running there is no traffic. [admin@eisy ~]$ sudo tcpdump -i tap0 -s0 -vvv tcpdump: listening on tap0, link-type EN10MB (Ethernet), capture size 262144 bytes Quote Link to comment
tazman Posted March 10 Author Share Posted March 10 @xKingif it just works for you I think that makes you a guru I appreciate the help and I hope you can follow my previous post ok! Quote Link to comment
xKing Posted March 10 Share Posted March 10 So what happens if after you bring the home assistant you do this sudo ifconfig vm-public up; sudo ifconfig tap0 up Also try adding this into `/etc/sysctl.conf` and reboot net.link.tap.up_on_open=1 Quote Link to comment
tazman Posted March 10 Author Share Posted March 10 3 minutes ago, xKing said: So what happens if after you bring the home assistant you do this sudo ifconfig vm-public up; sudo ifconfig tap0 up @xKingthat brought it up! Now will that carry over on reboot or is there something we need to add somewhere? Quote Link to comment
xKing Posted March 10 Share Posted March 10 Do you have vm_enable="YES" In your `/etc/rc.conf` ? Quote Link to comment
tazman Posted March 10 Author Share Posted March 10 13 minutes ago, xKing said: Do you have vm_enable="YES" In your `/etc/rc.conf` ? Yes Quote Link to comment
xKing Posted March 10 Share Posted March 10 Stop home assistant, reboot eisy, do check this sysctl -a | grep net.link.tap.up_on_open Quote Link to comment
tazman Posted March 11 Author Share Posted March 11 52 minutes ago, xKing said: Also try adding this into `/etc/sysctl.conf` and reboot net.link.tap.up_on_open=1 Added 25 minutes ago, xKing said: Stop home assistant, reboot eisy, do check this sysctl -a | grep net.link.tap.up_on_open Output [admin@eisy ~]$ sysctl -a | grep net.link.tap.up_on_open net.link.tap.up_on_open: 1 But if I try to enable vm_list="homeassistant" in rc.conf the virtual switches are not UP any more. Quote Link to comment
tazman Posted March 11 Author Share Posted March 11 (edited) On 3/9/2024 at 1:07 PM, KSaccullo01 said: Restart HA as a CRON job. Have CRON wait 3 minutes before starting HA. @xKingthis was a suggestion that might help now? Edited March 11 by tazman Quote Link to comment
tazman Posted March 11 Author Share Posted March 11 @KSaccullo01I tried putting the below line at the bottom of the /etc/crontrab and homeassistant does not start for me. @reboot sleep 180 && vm start homeassistant Quote Link to comment
xKing Posted March 11 Share Posted March 11 No you don’t need any cron Can you post your complete /etc/rc.conf please Quote Link to comment
tazman Posted March 11 Author Share Posted March 11 ###MAINTAINED BY UDX#### ###DO NOT MODIFY### hostname="eisy" # Set dumpdev to "AUTO" to enable crash dumps, "NO" to disable dumpdev="NO" zfs_enable="YES" dbus_enable="YES" sshd_enable="YES" moused_nondefault_enable="NO" sendmail_submit_enable="NO" sendmail_outbound_enable="NO" sendmail_msp_queue_enable="NO" clear_tmp_enable="YES" #NTP ntpd_enable="YES" ntpd_sync_on_start="YES" #HDMI is disabled by default #kld_list="i915kms" #Make sure dhclient is run in the background background_dhclient="YES" #make sure we support double stack ipv6_ipv4mapping="YES" defaultroute_delay="0" #Network Interfaces (default) rtsold_enable="YES" #for now, do not let iwlwifi/iwm get loaded devmatch_enable="YES" devmatch_blocklist="if_iwm if_iwlwifi" UDX_UPGRADE_STATUS="active" ifconfig_re0_ipv6="accept_rtadv" ifconfig_re0="DHCP" ifconfig_re0_ipv6="inet6 accept_rtadv" vm_enable="YES" vm_dir="zfs:storage/vms" vm_list="homeassistant" mdnsresponderposix_flags="-f /usr/local/etc/udx.d/static/mdns.services" ~ ~ ~ ~ Quote Link to comment
tazman Posted March 11 Author Share Posted March 11 @xKing with that rc.conf and the line out of cron homeasstant starts but vm-public and Tap0 are not "UP" Quote Link to comment
xKing Posted March 11 Share Posted March 11 Ok, try commenting out just `vm_list` from `/etc/rc.conf` and comment out the line you put in `/etc/sysctl.conf` reboot and see what does the `sysctl -a | grep up_on_open` say? you also have a duplicate ifconfig_re0_ipv6 in /etc/rc.conf - please delete the second one Quote Link to comment
tazman Posted March 11 Author Share Posted March 11 @xKingthe lines are a little different which one should go? ifconfig_re0_ipv6="accept_rtadv" ifconfig_re0_ipv6="inet6 accept_rtadv" With the 'vm_list' out and '/etc/sysctl.conf' line out [admin@eisy ~]$ sysctl -a | grep up_on_open net.link.tap.up_on_open: 1 Quote Link to comment
tazman Posted March 11 Author Share Posted March 11 @xKingattached is my homeassistant.conf file is there any other VM configuration you know of? loader="uefi" cpu="2" memory="2G" network0_type="virtio-net" network0_switch="public" disk0_name="disk0" disk0_dev="sparse-zvol" disk0_type="virtio-blk" uuid="EDIT" network0_mac="EDIT" #graphics="yes" #graphics_wait="yes" Quote Link to comment
xKing Posted March 11 Share Posted March 11 That looks fine, so what happens if you do `sudo vm start homeassistant` now - would tap0 still come up with no “UP” flag and require `sudo ifconfig tap0 up` ? Delete this: ifconfig_re0_ipv6="inet6 accept_rtadv" Quote Link to comment
tazman Posted March 11 Author Share Posted March 11 @xKingfor this instance everything started fine Tap0 is UP and home assistant became available at homeassistant.local:8123 but I don't know that it would happen all the time unless it is just a matter of starting HA after everything else. Quote Link to comment
tazman Posted March 11 Author Share Posted March 11 @xKingI restarted again and after starting HA the vm-public and Tap0 were not 'UP' Quote Link to comment
xKing Posted March 11 Share Posted March 11 Just to clarify - when you say you restarted and interfaces were not up - do you mean that you have vm_list=“homeassistant” uncommented? Or you booted and did `vm start homeassistant` manually? Quote Link to comment
tazman Posted March 11 Author Share Posted March 11 @xKingI rebooted eisy and 'vm start homeassistant' I don't know why but it seems inconsistent how it works. Quote Link to comment
Join the conversation
