Can we turn on controller back lights?
btreinders
On 3/23/2024 at 5:37 AM, btreinders said:
With the Elk module we could turn on back lights for buttons on the controllers.  Is there a plan to update the plugin to do this?
Sorry, I'm not sure what you are asking for can you be more descriptive?
On an arming panel you could turn on the backlight for say F1 when a light is on or in my case the garage door is open, and of course turn it off based on door position or a light status or whatever.
Is that a keypad or touchscreen? I don't think the Elk API gives access to that but I'll look it up.
Sent from my Pixel 8 Pro using Tapatalk
I do this for my garage door also.
In the meantime, you can use ElkRp2 to do this. You can trigger an output when the item (example garage door) is open/closed and then create a rule in ElkRP2 to turn the keys backlight on/off as wanted.
@DennisC I don't see how to do this in the ElkRp2 software.  Can you describe where that is located?  I don't see a category in the "then" portion of rules that will do this.  I can set an output for the "whenever" portion but I don't see the back light for a function button.  Thank you!
It has been a long time since I set this up, so I needed to go back and look.
You can turn on a function key from either a zone or an output. Once you have either the zone or output setup, then go to ElkRP2 - Keypads - Keypad # (you would need to do this for each keypad you want the F key to light for).
In the definable key selection, go to the line that corresponds to the F key you want to light, and select either the zone or output from the drop down under "Illumination Event".
Then place a check mark in the box for that F key under "Blink Light".  If you want, you can invert the light by placing a check mark under "Invert Light".
When finished, don't forget to save and upload to controller.
Edited by DennisC
added save
  • 3 weeks later...
  • 8 months later...
      380.1k
