Tempest - Light Intensity (LUX)
Just installed the Weatherflow Tempest but do not see the LUX reading, just UV.  Am I missing something or is this a feature request?
Do you mean that the value is empty or that it doesn't exist?
In the PG3 node list for the plug-in, it should show up like this:
In the admin console, it's the second to last entry, followed by battery voltage.  Make sure your admin console window is large enough to show all the values, it will truncate those that don't fit in the current window size (no scaling or scrolling in the AC).
Thank you, I was looking in just the admin and now I see it per what you suggested and under Illumination if you want to call it for programs.  Thanks again.
yes, I have this and it works, but the admin console doesn't cooperate with showing it.  it cuts off at the bottom of the page and I cannot figure out how to make it show up to see what it is.
any suggestions:
any suggestions:
I've changed the display resolution, so all the information is viewable.
9 minutes ago, someguy said:
@dbuss
will you please be more specific. 😀
Right-click on your desktop and click on "Display settings". Then, choose a resolution that allows you to view all the information in the admin console.
If you just want to see the value you can see it in PG3 as Bob shows above or if you have UD Mobile it handle the nodes with more entries better.
This happens for any of the plugins with a lot of information to display. I opened a support ticket over a year ago asking for a scroll bar to move the page down.
I was told it would be added to the admin console, but was advised it would not be soon and no ETA was given.
For now, changing resolution is the only option for the admin console.
