eisy IoX OpenADR dashboard won't save any settings
We had issues with the requirement for Java 8. That is resolved.
We can open IoX, then the OpenADR dashboard.
We have successfully used an ISY994 at a different site for 2 years on OpenADR.
Problem:
Nothing we define for OpenADR is saved. We have done
  • Settings (e.g. profile, VTN URL, enable, etc) -- "save" is enabled & we click it
  • certs (according to the config instructions). We import, have correct password, client cert shows its params. "save" is not enabled but we have no error message
When we go back to each of those sections, they are blank as if never  set.
Obviously then no attempt is made to connect to VTN, so there is no event output. Error logs etc at main IoX level show nothing.
Thank you.
Seems to be resolved.
Started all over again, clear cache, etc. Now remembering certs & settings.
