ELK Node Server not connecting via UD Mobile when connected via Cloud
When I am away from home and therefore connected via the cloud, ELK nodes do not update on my favourites screen nor can I connect to the PG3 node server on the Plugins (BETA).
Anyone else having the same issues?
Sorry, I should have mentioned that I use an iPhone.  I've also noticed that when I am on my local WiFi only the first in the list of Local Networks works.  The other WiFi networks in the list are on the same VLAN and therefore my iPhone has the same IP address.
Only the ELK node server does not respond when on these other WiFi networks.
I was on firmware 5.8.0 and upgraded to 5.8.3 and my UD Mobile is at 1.1.64.  Nothing changed, my favourites do not update and I cannot connect to the Admin/ Plugins (BETA) to see the Node Servers, I get the following error (see attached image).
Thank you.
