TotalConnect - Discovery Failed
Hi, just getting started with Node Servers for my eisy. I installed the TotalConnect NS and had disconnected/deleted it before experimenting with it while trying to troubleshoot a different problem. I reinstalled it in the same slot and now get this error message "Discovery failed please checks logs for a more detailed error". My log is attached. I was sure that when I first installed I could see arm/disarm status, but now the TotalConnect Controller shows no status in the IoX AC. Thanks in advance for advice.
TotalConnect_6-4-2024_115206_AM.zip
Solved by bpwwer
My fault.  I tried updating the plug-in to use a newer version of the total-connect-client library and apparently the changes in the library are not compatible with the plug-in.
I've reverted it back so re-installing should fix the issue.
Bob, Thanks a million, it's working to show armed/disarmed status and control.
Dale
Edited by DaleSWA
fix typo
