Error when trying "Backup IOX"
Hi,
I periodically backup my EISY using the 'file' - then 'backup iox'.  It hasnt been an issue in the past but for some reason now it is.
The error is:  Could not retrieve file ./FILES/CONF/27EC8F.REC.  Then the backup fails.  I rebooted the EISY but it is still having the same error.
My Firmware is 5.8.0
UI is:  5.8.0
Any ideas what to try to backup my data?
Rich
I had a related kind of problem a few years back. Its a problem with the Insteon device with the address 27EC8F
First, see if the device is working, configured properly, look at the options. Is it an iolinc? My similar issue was with an iolinc. Here is the thread
Hi - Thank you for helping me.
It is a Insteon Motion sensor - 2842-222 v.41
Interestingly enough - it is currently sitting in a dark room and the dusk/dawn sensor isnt showing anything.  Would a dead battery in a motion sensor cause the issue?
In your device tree, disable the motion sensor then try the backup again
The battery state shouldn't make a difference as the device is usually asleep when you do a backup.
Hi,
I do have it disabled, rebooted the Eisy & still having the same issue when backing up.  I could try to delete it but i do have some programs using it.
Rich
What type of device is 27.EC.8F
Try doing a diagnostics / compare on the device to see if the link tables are damaged.
Sometimes this is a corrupt file and causes the backup to fail.
I would suggest opening a ticket with UD to get support as to how to fix this. If you're comfortable with SSH commands it might be simple, but don't want to send you down that path without UD Support giving you the information of what to look at and what to alter.
