Change EISY Admin Console Timeout
Solved by paulbates
I don't believe there is a time out, per se. It's not designed to be left running, when you're done working, close it down.
Having said that, I forgot to shut it down sometimes and it will run for days before I notice. But I try to remember to shut it down
I never shut mine down.  However, every once in a long while (a week or two maybe?), it gets locked up and I use Task Manager to shut Java down and then I start it up again with no ill effects.
I like having it available at all times as I tend to tinker!
Me too, and PC is wifi connected. Can't remember the specifics, but after many days, certain things in the interface stop working and makes the windows "bling" sound.
It is handy for tinkering. I "tinker" too, especially tuning programs with variables.. when something unexpected does (or doesn't) happen.. I go see all of the variables on one page, last change time, etc
However, its not designed for that and to answer the OP, there's no setting to control that
Edited by paulbates
