EISY can't see my Zooz dongle
Having an issue where my EISY can't see my Zooz dongle. I have Z-wave "on" an see this.
@BAbdallah What firmware are you running?  (Help -> About)
[If not on IoX 5.8.4 (current as of this post) please update]
Have you attempted a full power cycle? (pressing the power button 6 times should shut down the eisy then you can pull the power, wait 10-20 seconds and plug it back in (with the dongle attached).
Allow 2-3 minutes for the device to fully boot and stabilize before you open admin console.
If still not seeing it please open a support ticket with UD.
Did you select ZMatter migration at one point?
My brother did and was having the same problem with his Zooz dongle.
A ticket was required and a remote access visit by Chris to repair.
this worked.
To change back to Original Z-Wave do the following:
1) From a browser, go to the following URL:
  http://<your_IP_address>:8080/rest/zmatter/zwave/deactivateZMatterZWave
  You should see a "200" in the response
2) Restart IoX
