Trying to set this up
DJonas
I just upgraded from an older Isy to an eisy.  I had an Elk Tab on the old system.  I understand that there is no tab on this plugin, but I'm pretty sure I have not completed the install.  All I see in my UD interface is an Elk Controller listing and there is pretty much no information in there.  I have some messages in the Polyglot 3x page.  They are:
Can't start elk until configuration is fixed
host not defined ''
ERROR: 09/24/2024 08:07:02 See log for: ELK Controller: 'NoneType' object has no attribute 'panel'
user_code not defined ''
I'm not sure what to do about any of those.  Are there step-by-step instructions for setting this up?  Would like to get it running as I have a few programs that use Elk information.
That helped a lot.  How do I add a wireless zone?  I have Hardwired Main Bd, Hardwired Exp 2 and Wireless - Group 3.  I added area 3, but I don't see the equipment.  I am using input zones 1-35.
Hmm.. I have two wireless devices and they show up as any other node.
-Are yours working within the Elk environment ie: on the Elk program?
-are they showing in the nodes on the PGX web page?
If yes to both of the above, close the AC, restart the Plug in. After fully started and all nodes are found, then try to re-open the AC and see if they show.
If no to the above questions, you need to start with the first and solve that.
If no to the second question, be sure your areas are defined. I am not familiar with "Group".
Lastly in the AC, these items may be grouped under a name that isnt jumping out to you. Go thru your "My lighting" slowly and look for any item that you can expand that may be where the nodes are. See below screenshot. I have three groups of elk stuff.
14 hours ago, TROSEMAN said:
Do you have to know the port it is using?
Yes.. tag it onto the IP address with a colon. The port is set in the ELK software for under the M1EXP. I cant remember what the default is, but I know I changed mine and then used it in the Plug in configuration.
