Motion triggered scene and timers (double off being sent ?)
I tried looking through the forum, but could not locate anyone posting this scenario / problem ...
I have a number of motion or switch activated scenes running for years and while they work perfectly 99% of the time, you hit the scenario where the timer has JUST expired and a new trigger occurs (less than a second) ... lights go off, then on, then off
Example: basement stairs, motion triggers human, lights go on, human descends stairs, but does a turnaround trip ... the timer expires (light off sent) but within milliseconds of the off, human is detected, light goes back on for less than 1 second and then go off again ... stairs are dark
I use a variable to reset the timer if there is a lot of traffic in the stairwell, this seems to work well. I've looked through Log to see if double Off is sent, but only see 1.
Its like the perfect software race condition where the command "off" is sending and motion is triggering "on" to restart the script
Anyone guide me on what I'm looking for ?
CODE
Basement Stairs Trigger
        'Basement Stairs Mo' is switched On
        Set 'Basement Stair 3way' On
        $sBasement_Stairwell_Light_Timer  = 60
Stair Light Timer Decrement
        $sBasement_Stairwell_Light_Timer > 0
        Wait  1 second
        $sBasement_Stairwell_Light_Timer -= 1
        Run Program 'Stair Light Timer Decrement' (If)
        Set 'Basement Stairs 3 Way' Fast Off
Basement Stairs Light Stop
        'Basement Stair 3way' Status is Off
        $sBasement_Stairwell_Light_Timer  = 0
        Set 'Basement Stairs 3 Way' Off
        Stop program 'Stair Light Timer Decrement'
Edited by jim_
Have you set your MS to send 'ON' only or does it send 'OFF' also. This could be creating a race condition.
BTW: You may be creating a problem with the line
It shouldn't necessary. The timer changing will re-run the decrement program automatically. (providing ii is a STATE variable.)
Thanks larryllix for the reply
I removed the "Run Program" line and you are correct, the decrement works  :-)
With respect to "MS to send 'ON' only", is this the option ?  (2844-222)
Yes. If you have created a scene between your MS and the device then it will send an Off as well as your program. Usually it doesn't hurt anything but in your case there may be some signal racing going on.
Here is how I did this for my mudroom in an older installation.
I created a scene to directly, and instantly, turn ON (only) the lights from the MS.
The light switches (or Alexa vocal) can manually override the automatic off and yet still turn them off after a long period automatically. (people get used to automatic and don't use the switches).
Note: the timer here is retriggerable so constant motion in the mudroom wil extend the timer.
MudRm Lights.auto - [ID 0067][Parent 0017]
        'MudRoom / MudRm.MS' is switched On
    And 'MudRoom / MudRm.MS' is not switched Off
        Wait  5 minutes
        Set 'MudRoom / MudRm Potlights' Off
MudRm Lights.manual - [ID 00D4][Parent 0017]
 // * * Enabled to Run at Startup, If will run False, resetting everything
        'MudRoom / MudRm Potlights' is switched On
    And 'MudRoom / MudRm Potlights' is not switched Off
        Set 'MudRoom / MudRm Potlights' On
        Disable Program 'MudRm Lights.auto'
        Wait  2 hours <--- human forgets = turn them off
        Run Program 'MudRm Lights.manual' (Else Path)
        Enable Program 'MudRm Lights.auto'
Ok, so changes made ... now to wait for the event to occur in the next month ... maybe
