Kasa Devices to support
I have confirmed all my current Kasa devices work as expected.  Those of you that have Kasa devices which are not currently working, please checkout my Amazon Wish List and if you see your device then grant the wish if you want it supported.  No guarantee on getting it right away, but I will try my best.  If your device is not in the list, please post link in this thread and I will add it.  This plugin is so inexpensive I can't justify purchasing all the different devices unless I decide to charge extra for the next upgrade, which is an option I will consider.
Thanks, I added a black on to the list since it was cheaper.
Personally I don't use many Kasa devices since they only update when polled, not push. Hopefully once matter is all working we can just use their matter supported devices.
Sent from my Pixel 8 Pro using Tapatalk
Thanks Guys for the HS200 and KP125.  The good news is that I have released 3.2.0 to Beta, but the bad news is that it requires an update to the python-kasa library I use.  So once that library is released you can test.  I'll be heading out of town this week but will keep an eye on it and let you know when you can give it a try.
Please do not install this beta for production, there were a lot of changes and I've only done minimal testing.
@Jimbo.Automates
I have been traveling so I haven't had a chance to try this.  I went to the non-production store to install 3.2.2 and there is an activate button.  When I press the button, it wants me to purchase a license.  The description says free trial. Am I doing something wrong?  Also do I need to do an update of PG3x 3.2.27?  IoX is 5.8.4.  Can the old and new versions coexist? Thanks for supporting this.
I am successfully running the Kasa 3.1.4 plug-in on an EISY (29 nodes) without problems but I recently purchased some EP25 Kasa plugs and was trying to install the plug-in beta version to see if I could get these to work. I tried to install it to a new slot. When I try to install the version 3.2.2, it stated that my trial period has expired and when I try to install the version 3.2.1, it shows up as “disconnected“. It looks as if it cannot locate certain modules. I have attached the log package, but please let me know if you need any other information.
Kasa_12-13-2024_122055_PM.zip
OK trying to add a new Kasa device (tapo actrually) but wehn I put iin my Tapo app it will not add it to my Poilsy, I have reboodted th NS a few time and all of my other ones are there but not my new one
Are you running the beta version? I thought it wasn't working for anyone.
oh man please help, now nothing is working not even my provious ones, I reinstalled the NS it says active and found the nodes but none of them work
was all working last night just could not add any new ones.  I see ther is a beta in the non-prodcution store, tried that also, but that would not even start, so deelted it.  I am running the prodcution version 3.1.4 but now nothing is working, shoot was depending on this more and more
OK, deleted it and reinstalled the 3.1.4 in a differnt slot, now working on my older ones (but of course did not find the new one that I had added yesterday)
OK, just to make sure I am doing it correctly (only using prodcution version), I should just be able to add it to myTapo app on my phone and it should show up on the NS, correct?
No, as I said, the newer devices do not work with the production plugin.
On 12/10/2024 at 7:52 AM, mjrush said:
@Jimbo.Automates
@mjrush Did you purchase it?  It's free so there should be no charge.
@bmercier I have the beta version
Edition: Free
License Type: Trial
Recuring: 1
Recuring Period: Month
Why does it ask them to "Purchase"?
- Jim
@Jimbo.Automates@bmercier
I have 3.1.4 installed, which I purchased a while ago.  The non-production store shows 3.2.1 and 3.2.2.  3.2.2 is listed as free but when I push the activate button it takes me to the portal and PayPal to buy it for $30.  Do I need to install 3.2.1 first since the button is install?
From the popup window:
You currently do not have a valid license for this version of Kasa. Please click on the purchase button below.
NOTE: After completing your purchase return here and click on Install.
Purchase takes me to the portal and PayPal.
