polyglot/PG2
I'm finally getting around to moving from my venerable ISY994 to EISY.  The migration instructions are clear and I've updated both IoX and the EISY to the latest versions (5.8.4), and also PG3x to its latest version (3.2.27).  I have a number of node servers using the original Polyglot and talking to the ISY994.  I realize that many (all?) of these can't be immediately migrated to PG3x versions, so I would like to check on the configuration details of these before moving to the PG3x versions on the EISY.  However, I'm having trouble accessing Polyglot to see these older node servers:  http://"ISY IP address":8080 doesn't work - "can't open the page because the server isn't responding"   What am I missing or doing wrong?   I saw references in some threads that once one updates to PG3x, it's no longer possible to see the PG2 home page?  If this is correct, then why or how do Polyglot or PG2 node servers continue to run (in my case on the ISY994.  Thanks, John
It's port 3000 for eisy / pg3
http://"eisy IP address":3000
You'll want to continue to access the pg2 on whatever you were running that on, on its ip address, not the eisy's.. rpi?
Edited by paulbates
inovermyhead is asking about PG2 not PG3
I have the same problem I have an rpi running some pg2 node servers.
http://"rpi IP address":3000 doesn't work
http://"rpi IP address":8080 doesn't work
