Blackbird Posted Thursday at 01:45 AM Posted Thursday at 01:45 AM Is there a way to use Insteon dimmer's Fast on/off for an automation in HA? I want to double tap my dining room light on to temporarily disable my Aqara presence sensor. Thanks Quote
larryllix Posted Thursday at 02:56 AM Posted Thursday at 02:56 AM If ..... XXX is switched Fast On Then .... do the deed Else -- This is also sent by the non-Dimmer Insteon Wall switches Quote
Blackbird Posted Thursday at 06:04 AM Author Posted Thursday at 06:04 AM 3 hours ago, larryllix said: If ..... XXX is switched Fast On Then .... do the deed Else -- This is also sent by the non-Dimmer Insteon Wall switches I know how to use fast on/off on the isy. I'm asking how to use it in Home Assistant. In HA there is no option that I can see that detects when an Insteon dimmer is switched fast on/off. Quote
Guy Lavoie Posted Thursday at 02:33 PM Posted Thursday at 02:33 PM I know nothing about Home Assistant, but if there is no built-in way to detect that command, could you do through an alternate way, using a ISY program that detects it, changes a variable or something, and then Home Assistant detects that? Quote
Blackbird Posted Thursday at 04:07 PM Author Posted Thursday at 04:07 PM 1 hour ago, Guy Lavoie said: I know nothing about Home Assistant, but if there is no built-in way to detect that command, could you do through an alternate way, using a ISY program that detects it, changes a variable or something, and then Home Assistant detects that? I was wondering about that also. Quote
IndyMike Posted Thursday at 04:08 PM Posted Thursday at 04:08 PM (edited) You are correct that there is no direct method to detect a "fast on" in home assistant. @Guy Lavoie's technique is the best way of informing HA of a fast on event. EDIT: Incorrect - See @shbatm response below Fast on events will always send a device to 100%. If your normal On/scene operation is less than 100%, you can trigger on the 100% level as a FAST ON. Using the "entity" trigger, the following will interpret a 100% ON as a fast on. The 100% level is 255, so you are testing for something above 254. Yaml: alias: Test Fast ON description: "" triggers: - trigger: numeric_state entity_id: - light.bsmt_fam_cans attribute: brightness above: 254 conditions: [] actions: [] mode: single Edited Friday at 12:13 PM by IndyMike Quote
shbatm Posted Thursday at 05:39 PM Posted Thursday at 05:39 PM (edited) Use an event trigger to pick up specific commands (independently of the device state) triggers: - event_type: isy994_control event_data: entity_id: light.main_bathroom_recessed_left control: DFON trigger: event Example Blueprint: https://gist.github.com/shbatm/5b48d2272fb136557ac9b77d2de1beb3 Docs: https://www.home-assistant.io/integrations/isy994/#handling-insteon-or-other-isy-control-events Edited Thursday at 05:41 PM by shbatm 1 Quote
