watson524 Posted Saturday at 01:27 PM Posted Saturday at 01:27 PM Hi all, currently running an isy and the license for remote access has run out. I don't feel like going to an eisy right now (Christmas lights on programs) but I do miss the remote control. If I renew the isy remote access License and switch to an eisy over the winter, will the license transfer or be prorated? Quote
Solution paulbates Posted Saturday at 01:32 PM Solution Posted Saturday at 01:32 PM You can add a new eisy to your renewed account @ my.isy.io Quote
watson524 Posted Saturday at 01:32 PM Author Posted Saturday at 01:32 PM Just now, paulbates said: You can add a new eisy to your renewed account @ my.isy.io Stellar, thanks for that info! Quote
watson524 Posted Saturday at 02:04 PM Author Posted Saturday at 02:04 PM One other quick question... I see there's a z wave board/enclosure and enclosure only. My isy has the wave built in so I assume there's not a board I can pull out of that and just put in a new enclosure or is it not worth the hassle? Quote
paulbates Posted Saturday at 02:12 PM Posted Saturday at 02:12 PM Not a zwave user. I'd search the forum for that topic, even recently some discussions about it. If that doesn't answer it, post a new topic in the right sub-forum Given the name of this thread, the new question will likely not be seen by many. Quote
Guy Lavoie Posted Saturday at 02:50 PM Posted Saturday at 02:50 PM 43 minutes ago, watson524 said: One other quick question... I see there's a z wave board/enclosure and enclosure only. My isy has the wave built in so I assume there's not a board I can pull out of that and just put in a new enclosure or is it not worth the hassle? No, the 300 or 500 zwave board in the older ISY cannot be used with a eisy. The eisy uses either a Zooz 700 series dongle, or the Zmatter board, installed as a USB device. Quote
watson524 Posted Saturday at 03:07 PM Author Posted Saturday at 03:07 PM 15 minutes ago, Guy Lavoie said: No, the 300 or 500 zwave board in the older ISY cannot be used with a eisy. The eisy uses either a Zooz 700 series dongle, or the Zmatter board, installed as a USB device. OK thanks. I wasn't sure what was what given the housing has 2 coax looking connectors on it Quote
Guy Lavoie Posted Saturday at 03:11 PM Posted Saturday at 03:11 PM The two connectors are for the zwave and zigbee antennas. Quote
watson524 Posted Saturday at 03:37 PM Author Posted Saturday at 03:37 PM 25 minutes ago, Guy Lavoie said: The two connectors are for the zwave and zigbee antennas. Ahh thanks! Didn't know such a thing was an option. I just figured more non battery z wave devices = better reception and that's as much as you could do Quote
