How to Add an I3 device
I have an eisy at revision 5.8.4. I have an Insteam WRo1 I3 outlet module I would like to add to my system. This device did not come with any address printed on it.
How do you add I3 devices in hthe admin console?
Solved by paulbates
The address is printed on the front, bottom right of the faceplate mount as you face the outlet. Small type, with a qr code you can scan.. It's meant for scanning it into an insteon hub, but it will come up and you can read it on your phone
You can also put the eisy in linking mode, press the set button and have the eisy find it
Edited by paulbates
