January 10Jan 10 Seems there is an issue - you can try to reinstall I changed the install style Edited January 10Jan 10 by Panda88
January 10Jan 10 Author Okay great! My lock is now showing up in the test node.Didn’t see what it looked like like in the AC I’ll look forward to the production update and thanks!
January 10Jan 10 Seems like the log you sent is old Can you generate a new one - manually opening the lock and then try to control it from teh AC as well . I am a little guessing on the control (until official API is posted)
January 10Jan 10 Author Here is the log. I controlled the lock several times manually and from AC YoLinkTest_1-10-2025_80937_AM.zip
January 10Jan 10 Author When using the test plug-in none of the nodes seem to update in the AC. Edited January 10Jan 10 by drprm1
January 10Jan 10 Maybe you can try to stop the regular node server while testing I found part of the issue with the new lock - I can likely get to retrieve data fairly easily, but controlling it may be more difficult without documentation
January 10Jan 10 Author Pretty sure I stopped the regular node for this test...Did another log. Started test plug-in and let it find all nodes for a few minutes then I used the AC to lock, unlock, and query several times then locked and unlocked several times manually. (regular node was stopped) Here's the log YoLinkTest_1-10-2025_80937_AM.zip Edited January 10Jan 10 by drprm1
January 10Jan 10 thanks it will not work yet as the syntax is not correct yet I'll get to it early next week
January 13Jan 13 Author Updated YoLink Test to 1.3.14. I can control lock via AC fine. Manually controlling lock or control by Yolink app the status in AC isn't updated. The node isn't updated correctly when using "update status" or "query" either. Even though I can lock and unlock using AC it shows Nodeserver status as "not connected" and connection state as "offline" YoLinkTest_1-13-2025_24659_PM.zip
January 14Jan 14 Can you try 1.3.15 I will only pick switches and locks - The code somehow gets the online status wrong, but I cannot figure out why - added some more debug info
January 14Jan 14 Author Nice! Works as it should. AC status updated when changed manually or by Yolink app. Can control from AC. Shows online and connected. (Nitpick, battery shows -1) Appreciate your efforts
January 14Jan 14 can you include the latest log - I'll try to fix the battery - should be easy - probably just reported differently
January 14Jan 14 Author Just now, Panda88 said: can you include the latest log - I'll try to fix the battery - should be easy - probably just reported differently YoLinkTest_1-14-2025_112114_AM.zip
January 14Jan 14 Does the new lock include a doorbell - if so can you try to press it and send me a log
January 14Jan 14 Author Here is the log with me pressing the doorbell a couple of times. Not sure who would use the doorbell its very hard to see the symbol on the keypad. YoLinkTest_1-14-2025_122453_PM.zip
January 18Jan 18 Author updated to 1.3.22 Dashboard shows "disconnected" If I try and start plugin a green pop up says "already running" No log is showing
