Multiple Partitions and Zone Connected to keypads Not showin
I had ioguy's nodelink running great on a pc for many years.  Well, I had an issue with that PC and had to redo it.  I am not able to reinstall nodelink and it doesn't seem like anyone has the answer for how to reinstall nodelink now that ioguy has taken the downloads offline.
Anyway, I had to shorten password to 6 characters and now it connects.
However, I have two partitions setup and a zone connected to a keypad and neither of those are showing up.  I know that they can be controlled/queried because nodelink worked with all of that.
Does this node not have the capacity to see these things or do I need to do something?
EDIT: Also using the command outputs.  but am not have any success.  There is an "activate" but no "deactivate".  I need to be able to turn the toggle the output on and off.
EDIT 2:  OK, it looks like the button "activate output" toggles the output.  But the status always says "active" once you have hit the button the first time and never changes after that.
EDIT 3:  Also, I have noticed that the partition state is not updating to "ready".  For example, I armed the system, it changed to "exit delay", then I disarmed the system, and it continued to say "exit delay".  I then opened a door and it changed to "not ready", I closed the door, and it still says "not ready".
EDIT 4: Also not getting the last arming/disarming user.  I armed then disarmed it from the keypad and it continue to say "0".
@Goose66
Edited by apostolakisl
First, a caveat: I no longer have a DSC alarm panel with an EnvisaLink so I have no way to test changes or updates to this plugin anymore.
That said, the installation/configuration instructions for the plugin are here:
https://goose66.github.io/nsdocs/evldsc-pg3.md
Answers to many of these questions may be found there. Spcifically:
1. The EnvisaLink does not provide a way to retrieve the panel configuration. You must configure the number of zones and partitions in the Custom Configuration Parameters, if different from the defaults. You must set the number of zones to include the zone number of the keypad connected zone, even if there are not intervening zones.
2. The command outputs came be configured on your panel to be in toggle mode or on/off mode, depending on your panel series. Unfortunately, as I mentioned above, there is no way to retrieve the configuration from the panel. So the plugin only support command outputs came activation, which toggles the command output on and then off based on the configuration of the panel. Once activated, the EnvisaLink will never clear the active status, so if always says active.
3. For partition state and zone statuses, this all worked several years ago, when I was using it, so I can’t really provide any insight on what may be happening without seeing any logs. But I will say it may just work differently from NodeLink, so if you can recreate a set of conditions and generate a log file in “Debug” mode, I can tell you if it is working as designed or not.
4. If the partition state never returns to ready when disarmed, this may be why the last disarming user is not set.
Edited by Goose66
@Goose66
Thank you for the response.  I missed where it said I had to configure the number of partitions/zones.  I didn't have to do that with nodelink and just assumed it pulled it down.  I added those and it appears to be good.
When I am back onsite I will see about the last user and the status going back to ready.  Currently the system is armed and it says that.  But it says 0 for the last user.
@Goose66
For whatever reason, it has started reporting last user now.  The cleaning crew showed up and their code reported. Perhaps it doesn't report the user until the exit delay is finished.  I armed and disarmed without allowing it to finish the exit delay when testing. I still can't say about reporting "ready".  I also rebooted polisy so maybe that did something.
However, there is one thing that is really important to a bunch of my programs that seems to be missing.  And that is status "disarmed".  Is there any chance this could be added?  I suppose I could go through and put "not armed" and "not exit delay" and not "entry delay" and not so on but that is really sloppy.  Since nodelink had "disarmed" I assume that is something that is reported.
Nodelink also had a heartbeat which was very helpful for me to know if something was going wrong with the system or internet or whatever.
EDIT: Actually, I don't think it would work right using the "not" statements.  I get notifications when the system specifically becomes disarmed from an armed state as well as turning the water on and some other things.
thx
34 minutes ago, GTench said:
Thanks for that.  Not sure I want to do this as I am already using pgm outputs for other things.  Since nodelink had right in the node server "disarmed" it seems like that should be something that the pg3 node can do as well.  The disarmed item in nodelink worked perfectly for 12 years now.  I just have a whole bunch of things that triggered on the system becoming disarmed.
I tried "not armed away", but that didn't work because it didn't trigger on disarming, it triggered on entry delay.  And putting two lines in there for "not armed away" and "not entry delay" doesn't work because many of my programs also run an else clause which would falsely trigger.
I guess I may be able to make a state variable and use that to track disarmed vs armed status and use that to trigger the programs.  But I would really prefer "disarmed" like nodelink.
@Goose66
Still having issues with system status not updating. System was armed, my staff came in at 7:09 and it updated to entry delay. They disarmed but that did not register in the node. Logged into envisalink and it showed system ready. Restarted the node but it still shows entry delay. Not sure how the node is supposed to get updated but it sometimes fails. I never experienced that with nodelink so I don't think it has anything to do with envisalink or my panel.
Using a variable to track armed states I seem to have worked out "disarmed" as a trigger, but only if the node accurately tracks system state.
The water supply turns on when the system disarms via isy. This did not happen. The node showed the zone that tracks valve status as closed. I manually triggered the cmd output that opens the valve and the node registered the zone change. But still it shows entry delay.
Edit. Just now another person entered the office and the node switched to not ready but never switched to ready after the door closed. Envisalink shows ready. So it seems like perhaps the node is not recognizing ready.
OF NOTE: In that partition, I have several zones that are not alarm zones.  Not sure if that would have anything to do with it.  But of course DSC is programmed to know those are not alarm zones so it shows "ready" despite those zones being open.  I kind of doubt this has anything to do with it since those zones were violated while the node said "entry delay" but envisalink showed "ready".
Also of note: partition 2 does report "ready".  To the best of my knowledge, partition 1 has never reported "ready".
As to NodeLink "reading" the number of zones and partitions configured, this is not a feature of the TPI (API) presented by the EnvisaLink, so don't know how it was doing that.
Similarly, a status of "Disarm" vs. "Ready/Not Ready" is simply a difference in the way the EnvisaLink-DSC plugin is designed vs. NodeLink. The EnvisaLink sends a "partition disarmed" command but that's generally immediately followed by a "partition ready" or "partition not-ready" command. Perhaps NodeLink handled these states separately.
The Plugin does send a heartbeat every few minutes. From the document linked above:
Quote
5. The plugin sends an AWAKE command (heartbeat) to the Alarm Panel node every four minutes (when the keepalive is received from the alarm panel). You can check for this in a program on the ISY to monitor the connection. There is also an "Alarm Panel Connected" driver value that reflects whether the connection to the EnvisaLink/alarm panel is active, but this may not get updated if the plugin fails.
Don't know about "non-Alarm Zones" - never experienced or tested that. Perhaps you should try specifically bypassing these. I will try and take a look at the log files tonight to figure out why the partition never goes to "Ready".
It would be real nice if the "disarmed" output from envisalink was run through even if it is immediately followed by a status such as ready or not ready.  I have it working by using a variable.
But the main issue and I sent you a PM, is that the "ready" state is never happening on partition 1.  It always shows whatever immediately proceeded the ready state.
Regarding heartbeat.  I am accostomed to that showing as alternating 1 and -1 and use a program that runs continuously in with a wait that gets reset by the value changing.  How is this working?  I see "panel connected" in the programming, is that just always 1 when connected and not really a "heartbeat" in the sense of a "beat" between 1 and -1?
Took a look at your log and sure enough it's a bug. Your EnvisaLink sends a "Partition Not Ready" for partition 1 but then follows up 3 seconds later with a "Partition Ready – Force Arming Enabled." The description of this command is the same as "Partition Ready," but I am guessing it has something to do with all the open zones that are configured as "non alarm zones." Paradoxically, the current code actually checks for the "Partition Ready – Force Arming Enabled" command and handles it the same as a "Partition Ready" command, but for what ever reason, the "Partition Ready – Force Arming Enabled" command doesn't make it to the state handler for the partition node and is instead marked by the API as an "Unhandled" command. It's a simple fix.
However, it's been almost 3 years since I touched this code and a lot in the environment has changed. I'm not sure if I need to bring this one up to new standards or just make this one change and push it out. Bringing it up to new standards would mean less likely that it would be blown up by some new PG3/IoX release. I could also implement some other todos, such as upping the password to 10 characters, adding names to the state (driver) values, adding additional events (commands) for "Partition Armed" and "Partition Disarmed", adding disarm with custom user code, etc. But the problem with doing all this is I have no way of testing it because I don't have a DSC panel anymore. I would need to get a VPN setup to somebody with a DSC panel and EnvisaLink to test/debug changes.
Just implementing the "Partition Ready – Force Arming Enabled" command handling would be easy (one line changed) and would (hopefully!!!) not introduce any bugs so I could just push it out.
What do you think?
Edited by Goose66
Also, it appears the partition node is already receiving an event (command) when the partition is disarmed, but it is currently labeled "Alarm Restored." Instead of the complex code you posted for determining disarmed, try:
        'DSC PG3 / Keypad MDPA' is switched Alarm Restored
        <Partition has been disarmed>
The name of this command can be changed from "Alarm Restored" to something like "Partition Disarmed" when we make the other change(s) if this works.
I need to run the Else clause when armed.  So what would you suggested for the "if" clause for that.  "Triggered" is the other option, but I don't know what "triggered" means.
"Is
    And
        'DSC PG3 / Keypad MDPA' is not switched Alarm Triggered
          <partition has been armed>
Or perhaps mix and match status with control?
      And
        'DSC PG3 / Keypad MDPA' is not armed away
I'm afraid any status change in the alarm will trigger the second program to run.  That might be fine, I'd have to think about it.
Maybe if I have to make it two programs?
Yes, two programs. And we will need another event (command) for arming. By having them in two separate programs, you won't need the complimentary "not" statement for events (commands) in your if statements.
Currently the events (commands) sent to the Partition node are Alarm Triggered (DON) and Alarm Restored (DOF). This was done to make programming for responding to these events easier as well as the Partition node to be dropped into a scene as a controller. However, the way it appears to be coded right now, the Alarm Restored event (command) will be sent whenever the partition is disarmed, regardless of whether the partition was alarming or not.
I suggest changing the code to send the following events (commands) for the Partition node:
Alarm Triggered (DON) - the Alarm has been triggered
Alarm Restored (DOF) - when the panel is alarming and is subsequently disarmed (thus cancelling the alarm)
Partition Armed (DON3) - when the Partition is armed
Partition Disarmed (DOF3) - when the Partition is disarmed
That should have you covered without changing anything for existing users.
What does "alarm triggered" even mean?
I am trying to keep this simple so I don't get all twisted about in the future when I might need to make changes.  Originally this all worked with 1 program and no variables.  I think this will work to keep it down to one program running the variable where "1" indicates the system is armed.  Perhaps I can ditch the variable, but I worry about the status armed away since all kinds of other states exist on that variable that will trigger this program when they change.
MDPA Armed State Copy - [ID 011C][Parent 0177]
     Or 'DSC PG3 / Keypad MDPA' Partition State is not Armed Away
        $sDSC.MDPA.Armed.State  = 0
        $sDSC.MDPA.Armed.State  = 1
Alarm Triggered means an alarm was triggered for the partition, i.e., the partition moved to an “alarming” state. Alarm Restored means (or at least is supposed to mean) that the partition was in an “alarming” state and the alarm has been turned off (presumably by disarming the partition).
These events (commands) are sent so that the partition node can be dropped into a scene as a controller to, e.g., turn on all exterior lights when the alarm is triggered, etc.
The Partition Armed and Partition Disarmed events (commands), once implemented, should satisfy your needs without needing any complicated state logic or trickery with Else clauses (which anybody who’s been around here for the past 12 years knows I think are basically worthless in the current programming paradigm). So, for example, two programs, one with “If 'DSC PG3 / Keypad MDPA' is switched Partition Armed” and the second with “If 'DSC PG3 / Keypad MDPA' is switched Partition Disarmed.” It’s also self-documenting.
Yes, control armed and control disarmed will totally solve my problem and will work using the else clause and will allow me to dump the variables as well as the programs that set the variables and have the action taken directly in the same program that monitors the alarm state.  I believe that will take me back to how I had it running with nodelink.
if
  system is switched armed
  or
  systme is not switched disarmed
  run if program for armed system
  run if program for disarmed system
While ISY logic doesn't lend itself to a lot of "else" use, I manage to use quite a lot with great success.  I use it tons in the following:
"If device a is control switched on
or device a is not control switched off."
To allow a "then" and "else" to mirror actions taken at the switch in a single program.
But I find other uses for it as well.  It is a bit of fun with logic exercise to get it working.
IF you need to put a beta for testing, I can install and test for you.
Thank you.
3 hours ago, Goose66 said:
@apostolakisl A new version (v3.1.9) of the plugin is in the Non-Production (Beta) store for testing. I know you know this, but when we have tested and move it to production, your programs with have to be adjusted.
I installed it.  I see control partition armed/disarmed.  Is that the only change?  Partition armed refers to armed stay or away?
"Partition disarmed" executed this morning correctly.  This afternoon I will be able to tell if you "partition armed" executes correctly.
System "ready" / "not ready" is showing appropriately as well on the partition with non-alarm zones.
So far, looking good.
Just looking at stuff here.  Nodelink monitored the dsc system but had everything as a status, no control values at all.  Not sure how this all works with nodes, certainly understand with Insteon as it is part of the protocol, but when it comes to Envisalink or I suppose other 3rd part nodes, is this just a call on the person writing the node as to how to categorize the data it receives from the monitored device (Envisalink)?
Short answer, yes.
Long answer is that I have always been of the opinion that the ISY and whole UD ecosystem was designed around Insteon/X10 at its core, including the programming model that allows for separate and distinct conditions for state changes and events (commands) (along with schedule, etc.), and I have always tried to design plugins that present nodes that fit within this paradigm.
I also try and mirror the devices’ native paradigm - what does the DSC keypads (or the EnvisaLink API) reflect as state vs. what events happen or are raised. In this specific case, I’ve also tried to maintain some consistency with the EnvisaLink Honeywell/Vista plugin, which i wrote from the same base code.
Edited by Goose66
Changes are listed in the updated release notes here: https://goose66.github.io/nsdocs/evldsc-pg3.html
“Partition armed” event refers to any arming. If you want to know how it was armed, you would have to check the state. But you would want to incorporate a delay to make sure that IoX had processed the state change which may or may not arrive before the “Partition armed” event.
Upon arming the system it did indeed register correctly.  So I think I should be in business.  I will have to give it a try now reverting back to a single program and eliminating the variable which I feel comfortable should work.
Thx.
Hi @Goose66, I updated to 3.1.19. I noticed, as per this thread, that partition disarmed has been added. Previously I was using Alarm Restored. Are those both driven from the same driver? Or is there some minor difference between the two?
-Tim
      37.8k
      377.5k
