Capitalization of User for Admin Consul vs PG3 dash vs SSH ?
Anyone else run into this .. I'm kinda embarrassed it took me a few cycles to try integrations of the capital for Admin / this is a new EISY on 5.8.4
(bug? = user capitalization here fails login .. must be in lower case for ssh but not for PG3 or Admin)
1.
IoX admin console login
admin/admin = FAIL
Admin/admin = pass
2.
Polygolt dash https://192.168.1.##:3000/dashboard
admin/admin = FAIL
Admin/admin = pass
3.
ssh either local or via IP
ssh Admin@192.168.1.## / admin = FAIL
ssh admin@192.168.1.## / admin = pass
Yes, I tried a reset of Admin user and password via Admin consul setting to User ID of Admin/ password of admin
Edited by junkycosmos
@junkycosmos IoX user/pass would then be the same for PG3x. The ssh user/pass is system generated so not the same as IoX (and not controlled/changed/updated if you change on IoX). So I think what you’re experiencing is to be expected. Not sure if you can “change” the ssh admin user to be capitalized. You can (and should) only change the pass for the admin user.
