DHouse02 Posted January 20 Posted January 20 I'm a rookie at this so please be patient. Issue: I want to activate UD Mobile but my 994 has 4.9 firmware. How do I upgrade the latest? Bigger issue: I have an eisy that I want to upgrade to as soon as I figure out how to do it. Is my rationale correct re upgrading the 994 firmware first or is it unnecessary?
DHouse02 Posted January 20 Author Posted January 20 Additional point re the planned eisy upgrade: the previous homeowner (who installed the 994) installed an Insteon EZ108SA I/O controller in the outside switchbox for the pool pump & light and landscape lighting. He also installed a PLM in the box as well. Since this is the core function that I want to maintain, does this not complicate the eisy upgrade? The PLM location is less than optimal since the unit is subjected to the vagaries of ambient temperature which necessitates rebooting the PLM fairly frequently (especially in the summer). If I move the PLM indoors (close to the eisy) then the CAT5 cable to the EZ108SA would be ~50 ft. I note in the PLM kit guide that the cable should be no longer than 10 ft. What should I do here?
paulbates Posted January 20 Posted January 20 Need some clarity, your ultimate goal is to upgrade the 994 to eisy and sunset the 994? If yes: Don't upgrade or make changes to the 994i Set up the eisy There are 2 PLM variants: USB version can go ~10' Serial can go ~50'... + UDI offers a serial > usb adapter I would get a new USB PLM for the eisy Set up eisy with the new PLM How many programs do you have and how big are they? If not a lot of programs and not that big, re-enter them into the eisy as you migrate devices, one room or one function at a time Come up with a plan to move one room or function of Insteon devices at a time to eisy Delete a room or group/function of IInsteon devices from the 994 Add them to the eisy and verify Add related scenes and programs Give it time to verify everything works Go to the next room or function Not clear on the wiring need of the ezio, but you should be able to get a 50' CAT 5 or greater cable to work
Brian H Posted January 20 Posted January 20 You have two PLM's. One on the ISY994i and the other one is used on the EZIO8SA. The one on the EZIO8SA is probably a 2412S PLM or their equivalent. It would be power line only communications.
DHouse02 Posted January 21 Author Posted January 21 18 hours ago, paulbates said: Need some clarity, your ultimate goal is to upgrade the 994 to eisy and sunset the 994? If yes: Don't upgrade or make changes to the 994i Set up the eisy There are 2 PLM variants: USB version can go ~10' Serial can go ~50'... + UDI offers a serial > usb adapter I would get a new USB PLM for the eisy Set up eisy with the new PLM How many programs do you have and how big are they? If not a lot of programs and not that big, re-enter them into the eisy as you migrate devices, one room or one function at a time Come up with a plan to move one room or function of Insteon devices at a time to eisy Delete a room or group/function of IInsteon devices from the 994 Add them to the eisy and verify Add related scenes and programs Give it time to verify everything works Go to the next room or function Not clear on the wiring need of the ezio, but you should be able to get a 50' CAT 5 or greater cable to work Many thanks for the info. I'll double check the PLM. Also, I bought a new PLM some time ago but have not installed it. Currently, I don't have that many scenes. I tried to delete the unused ones (I replaced many of the Insteon light switches when our home remodel was done) but the system bogged down when it attempted to update. I think this was due to a lack of communication with the battery powered sensors in the crawl space (I need to check/replace the batteries). I was informed that I could bypass the battery-powered sensors but I don't know how. I want to automate the pool pump & light and landscape lighting. Afterward I want to add the security system (ELK) then the surveillance system. Beyond that, I will wait to see what we need. 18 hours ago, Brian H said: You have two PLM's. One on the ISY994i and the other one is used on the EZIO8SA. The one on the EZIO8SA is probably a 2412S PLM or their equivalent. It would be power line only communications. Thanks Brian. I didn't know this. I'll check.
DHouse02 Posted January 21 Author Posted January 21 On 1/20/2025 at 12:49 PM, Brian H said: You have two PLM's. One on the ISY994i and the other one is used on the EZIO8SA. The one on the EZIO8SA is probably a 2412S PLM or their equivalent. It would be power line only communications. Thanks Brian. I didn't know this. I'll check.
DHouse02 Posted January 21 Author Posted January 21 Clarified that, yes, the system has 2 PLMs. The one closest to the 994 is located on the other side of the wall where the backup battery is located. I have a serial PLM that I ordered some ago but I don't have the serial PLM kit. I've have to order.
DHouse02 Posted January 22 Author Posted January 22 On 1/20/2025 at 12:36 PM, paulbates said: Need some clarity, your ultimate goal is to upgrade the 994 to eisy and sunset the 994? If yes: Don't upgrade or make changes to the 994i Set up the eisy There are 2 PLM variants: USB version can go ~10' Serial can go ~50'... + UDI offers a serial > usb adapter I would get a new USB PLM for the eisy Set up eisy with the new PLM How many programs do you have and how big are they? If not a lot of programs and not that big, re-enter them into the eisy as you migrate devices, one room or one function at a time Come up with a plan to move one room or function of Insteon devices at a time to eisy Delete a room or group/function of IInsteon devices from the 994 Add them to the eisy and verify Add related scenes and programs Give it time to verify everything works Go to the next room or function Not clear on the wiring need of the ezio, but you should be able to get a 50' CAT 5 or greater cable to work Clarified that, yes, the system has 2 PLMs. The one closest to the 994 is located on the other side of the wall where the backup battery is located. I have a serial PLM that I ordered some ago but I don't have the serial PLM kit. I've have to order. Thanks for the guidance Paul. I only have 3 programs (home, security system, surveillance system). In the home, I don't have many scenes in the home program (pool pump & light, front & back landscape lighting - will add a few more in the future). Question: how do I move a single scene from the 994 (backup copy?) to the eisy?
paulbates Posted January 22 Posted January 22 You could, but I would simply look at the original and rebuild it from scratch on eisy... It will take less time
DHouse02 Posted January 22 Author Posted January 22 3 hours ago, paulbates said: You could, but I would simply look at the original and rebuild it from scratch on eisy... It will take less time Ok. Makes sense. On 1/20/2025 at 12:36 PM, paulbates said: Need some clarity, your ultimate goal is to upgrade the 994 to eisy and sunset the 994? If yes: Don't upgrade or make changes to the 994i Set up the eisy There are 2 PLM variants: USB version can go ~10' Serial can go ~50'... + UDI offers a serial > usb adapter I would get a new USB PLM for the eisy Set up eisy with the new PLM How many programs do you have and how big are they? If not a lot of programs and not that big, re-enter them into the eisy as you migrate devices, one room or one function at a time Come up with a plan to move one room or function of Insteon devices at a time to eisy Delete a room or group/function of IInsteon devices from the 994 Add them to the eisy and verify Add related scenes and programs Give it time to verify everything works Go to the next room or function Not clear on the wiring need of the ezio, but you should be able to get a 50' CAT 5 or greater cable to work Clarified that, yes, the system has 2 PLMs. The one closest to the 994 is located on the other side of the wall where the backup battery is located. I have a serial PLM that I ordered some ago but I don't have the serial PLM kit. I've have to order. Thanks for the guidance Paul. I only have 3 programs (home, security system, surveillance system). In the home, I don't have many scenes in the home program (pool pump & light, front & back landscape lighting - will add a few more in the future). Question: how do I move a single scene from the 994 (backup copy?) to the eisy?
paulbates Posted January 22 Posted January 22 26 minutes ago, DHouse02 said: Question: how do I move a single scene from the 994 (backup copy?) to the eisy? The rebuild comment was meant for the scene. Take a picture of or write down the current scene in the ISY. Create a new scene, under the link menu, on eisy and drag the related devices in
DHouse02 Posted January 23 Author Posted January 23 23 hours ago, paulbates said: You could, but I would simply look at the original and rebuild it from scratch on eisy... It will take less time Ok. Makes sense. Will do. On 1/20/2025 at 12:36 PM, paulbates said: Need some clarity, your ultimate goal is to upgrade the 994 to eisy and sunset the 994? If yes: Don't upgrade or make changes to the 994i Set up the eisy There are 2 PLM variants: USB version can go ~10' Serial can go ~50'... + UDI offers a serial > usb adapter I would get a new USB PLM for the eisy Set up eisy with the new PLM How many programs do you have and how big are they? If not a lot of programs and not that big, re-enter them into the eisy as you migrate devices, one room or one function at a time Come up with a plan to move one room or function of Insteon devices at a time to eisy Delete a room or group/function of IInsteon devices from the 994 Add them to the eisy and verify Add related scenes and programs Give it time to verify everything works Go to the next room or function Not clear on the wiring need of the ezio, but you should be able to get a 50' CAT 5 or greater cable to work Clarified that, yes, the system has 2 PLMs. The one closest to the 994 is located on the other side of the wall where the backup battery is located. I have a serial PLM that I ordered some ago but I don't have the serial PLM kit. I've have to order. Thanks for the guidance Paul. I only have 3 programs (home, security system, surveillance system). In the home, I don't have many scenes in the home program (pool pump & light, front & back landscape lighting - will add a few more in the future). Question: how do I move a single scene from the 994 (backup copy?) to the eisy?
Geddy Posted January 23 Posted January 23 1 hour ago, DHouse02 said: Question: how do I move a single scene from the 994 (backup copy?) to the eisy? Not possible. Either you migrate the entire ISY994 system to the eisy or you start from scratch and link and build scenes in the new eisy.
Brian H Posted January 23 Posted January 23 The PLM connected to the EZIO8SA is not connected to the ISY994i. It is programed by the EZIO8SA and is used to send and receive Insteon communications. From your ISY994i. So it would not be directly part of the change from the ISY994i to the eiay. When the eisy has the information from the ISY994i. It should be able to then access the EZIO8SA through it own PLM.
