UD Mobile on a PC
I found a thread from July 2021 asking if there is "any possibility of it (UD Mobile) getting ported over to run on a PC without using android emulators?  If not, is there a particular emulator that works well with it?" One of the answers was "We will be working on a web version in the future although it will be some time."
Any news? Thanks.
8 hours ago, mikek said:
Is there a particular emulator that works well with it?
I already had BlueStacks5 installed so I installed UD Mobile from Google Play for you.
Logged in with my Portal credentials.
Haven't tested extensively but seems to be working fine.
Just curious, does UD Mobile and Bluestack5 survive and work after a PC has entered sleep mode and reawakened?  The AC doesn't and requires exiting and logging in again after a PC wakes up. Thanks.
Thank you. I'll give that a try.
BlueStacks survives but UD Mobile needed a restart which amounts to a stop and start, about 2 seconds.
