Power consumption of Zmatter dongle
I want to place my Zmatter dongle outside my house in line-of-sight with the Zwave modules to maximize the range.   '
There is an open field between where I plan to put the Zmatter dongle and one of the controlled Zwave modules, so I can't bridge the distance with a mesh network of Zwave modules.
I plan to use a USB-to-ethernet extender to place it 40' feet away from the Eisy.  The Eisy normally powers the Zmatter dongle directly with a USB 3.0 port .  USB standards say that a USB port supplies 5V at up to 0.9A (4.5W).
I see on a Reddit post that some people have done something similar using a USB 2.0 USB-to-ethernet extender powering the Zmatter dongle.   USB 2.0 ports are specified to put out only 0.5A (2.5W) .  They said it worked, but the question is, how well ?
How well will the Zmatter dongle work if it is limited to 2.5W ?   Would it be expected to have better range if it were powered by a USB 3.0 port supplying up to 4.5W ?  What is the power consumption of this Zmatter dongle, it is not on the specs I can see ?
Solved by Techman
That's a great idea, and a less expensive option than what I was thinking.
Good reviews for the product on Amazon with one of the few critical comments saying:
"Great product but can get directly from Zooz for 10 dollars cheaper."
Thank you
Still it would be good to post somewhere the power consumption of this Zmatter dongle.
I would like to leave this post open until there is an answer to that question.
Edited by JohnC
state reason to keep open
Every time I've bought a Zooz device I've checked its price on Amazon.  It has always been higher on Amazon, with the difference being even greater than the shipping The Smartest House charges by a bit.  The only downside to buying direct is that it's hard to fully opt out of their annoying emails - but that's true of most companies, in my experience.
-Tom
Thank you
If you're looking for an answer, emailing UDI directly through their support channels is the best way to get it.
Per UD support:
"I don't have the exact specifications regarding power consumption. This said, it should by fully functional using the USB 2.0 port."
