Brand new eisy - update failure
Go to solution Solved by Michel Kohanim,
I have been running an ISY944i for a few years, recently unboxed a brand new eisy with intent to migrate to it following these instructions: https://wiki.universal-devices.com/index.php?title=Eisy:User_Guide
Plugged the new eisy to ethernet and power, used the UD Mobile app to connect it to my ISY account. I used the IoX finder to locate the new eisy, successfully logged into the Admin console. As a first step per instructions I went to Configuration tab and chose Upgrade Packages. Prompt told me to wait half an hour and when I came back an hour later the Admin Console had logged me out. I tried to find the eisy again via the IoX finder and it is not being discovered. I waited another hour and no change, so I pulled power to eisy and reconnected power. Waited another half hour and still IoX finder not locating the new eisy. Confirmed the ethernet port has link activity lights so doubt a network issue.
I am guessing update went sour. Anybody have experience in this? is there a factory reset process?
I'd start with the java clear cache (all 3 checkboxes) first. Then manually adding the eisy in the finder "https:/192.168.x.x:8443/desc"
Try that
11 minutes ago, Techman said:
@elliott9
It's normal for your admin console to shut down after a firmware update.
After you clear your java cache download the admin console from here:
    https://isy.universal-devices.com/start.jnlp
The admin console always needs to be updated after a firmware update
I just cleared java cache and used that link to open admin console, which opens the IoX finder. As before it does see my old ISY but the new Eisy is not discovered.
Posted (edited)
Try that
I just looked up the IP address in my DHCP server. Confirmed it was correct by SSHing into it, which required factory default credentials.
However looks like port 8443 isn't open as IoX finder reports to "Not Found" when I ender https://192.168.x.x:8443/desc (except using my IP of course). Also browser to that location also reports nothing.
I think upgrade went sideways somehow.
Edited by elliott9
Are you on a MAC or PC?
ISY Not Found
If IoX Launcher cannot find your device (ISY994 [EOL], Polisy, eisy):
  1. Most importantly, you need to reinstall the IoX Launcher
  2. VPN software is running on your computer or you're on a VPN network
  3. Unit is not on the same network as your compute. Perhaps you changed routers? If so: follow these instructions
  4. If not #1, please open your router page and see whether or not you see ISY994-EMS (for ISY994 [EOL]), polisy (for Polisy), or eisy (for eisy) in the list of LAN clients. If you find the IP address, then, in IoX Finder, click on the Add button and enter
    1. ISY994: http://1.2.3.4/desc (replace 1.2.3.4 with the actual IP of ISY in the router)
    2. Polisy/eisy: https://1.2.3.4:8443/desc (replace 1.2.3.4 with the actual IP of Polisy/eisy in the router)
  5. If not #2, then perhaps the unit is not powering on:
    1. ISY994: Please make sure the LED pattern is as outlined here
    2. Polisy: Reboot the unit, all 3 LEDs should get lit and then only the left most is lit. Wait for 30-60 seconds. You may hear a beep.
    3. eisy: Reboot the unit, allow 2-3 minutes for everything to boot and stabilize before attempting to open IoX Launcher
  6. If not #3, the issue is that you might have firewall/VPN or antivirus software (especially VPN) blocking network communications.
I have observed the same behavior. I was going to migrate my old ISY config to the new eisy. Was able to find the device and get the admin console up. Following the directions I proceeded to to an 'Upgrade Packages'. After a two hour wait for the update to complete, the interface was timed out. I tried to run IOX Finder to no avail. I looked at my DHCP server and found that the address had changes so I flushed the cashes and powered down the eisy and restarted it.  After a few minute wait I retried the connection - again with no luck. I tried explicit ip addressing with correct ports again no response. I am able to ping the eisy at the new ip address. I then SSH to the eisy and checked on the listened ports - i did not see 8443 in the list. In fact I only saw SSH. Running 'service -e' to list the running services is did not see anything that looked like IOX but I don't know what the correct service would be. I suspect that the IOX service did not restart after the upgrade. This is not an 'eisy' upgrade by any means.  Does anyone have a suggestion on something that I might have missed?
Just an FYI if you are using a Mac:
After the latest mac update, users must now enable local network access for chrome and Admin Console.  The permission dialog is only shown once, so if you denies/ignores it, you will need to manually enable on MAC > System Settings -> Privacy & Security -> Local Network
  • Like 1
Posted (edited)
I am on PC. but I will reiterate that the network and PC I am using were able to access the device just fine until I did the eisy update. nothing else has changed, has only been a few hours. something is up with the eisy upgrade.
These symptoms overlap mine 100%. Even my DHCP server shows it assigned a new lease. Nothing is running to listen to port 8443:
[admin@eisy ~]$ lsof -nP -iTCP -sTCP:LISTEN
lsof: WARNING: access /home/admin/.lsof_eisy: No such file or directory
lsof: WARNING: created device cache file: /home/admin/.lsof_eisy
[admin@eisy ~]$ sudo lsof -nP -iTCP -sTCP:LISTEN
Password:
lsof: WARNING: access /root/.lsof_eisy: No such file or directory
lsof: WARNING: created device cache file: /root/.lsof_eisy
COMMAND    PID   USER FD   TYPE             DEVICE SIZE/OFF NODE NAME
mosquitto 1272 nobody  4u  IPv6 0xfffff80146afea80        0  TCP *:1884 (LISTEN)
mosquitto 1272 nobody  5u  IPv4 0xfffff80146afe540        0  TCP *:1884->*:* (LISTEN)
sshd      1389   root  3u  IPv6 0xfffff80146afe000        0  TCP *:22 (LISTEN)
sshd      1389   root  4u  IPv4 0xfffff80026376a80        0  TCP *:22->*:* (LISTEN)
mosquitto 3668    isy 10u  IPv4 0xfffff80200e39540        0  TCP *:8881->*:* (LISTEN)
mosquitto 3668    isy 14u  IPv4 0xfffff80200e39000        0  TCP *:8882->*:* (LISTEN)
mosquitto 3668    isy 15u  IPv6 0xfffff80200d6aa80        0  TCP *:8883 (LISTEN)
mosquitto 3668    isy 16u  IPv4 0xfffff80200d6a540        0  TCP *:8883->*:* (LISTEN)
[admin@eisy ~]$
       netstat [-j jail] -Q
[admin@eisy ~]$ netstat
Active Internet connections
Proto Recv-Q Send-Q Local Address          Foreign Address        (state)
tcp4       0    128 192.168.200.194.ssh    192.168.200.142.54890  ESTABLISHED
tcp4       0      0 localhost.8883         localhost.47323        ESTABLISHED
tcp4       0      0 localhost.47323        localhost.8883         ESTABLISHED
tcp4       0      0 localhost.8883         localhost.41361        ESTABLISHED
tcp4       0      0 localhost.41361        localhost.8883         ESTABLISHED
udp4       0      0 192.168.200.194.ntp    *.*
udp6       0      0 fe80::7195:ca40:.ntp   *.*
udp4       0      0 localhost.ntp          *.*
udp6       0      0 fe80::1%lo0.ntp        *.*
udp6       0      0 localhost.ntp          *.*
[admin@eisy ~]$ service -e
/etc/rc.d/hostid
/etc/rc.d/zpool
/etc/rc.d/zpoolupgrade
/etc/rc.d/zpoolreguid
/etc/rc.d/zvol
/etc/rc.d/hostid_save
/etc/rc.d/kldxref
/etc/rc.d/zfsbe
/etc/rc.d/zfs
/etc/rc.d/devmatch
/etc/rc.d/cleanvar
/etc/rc.d/ip6addrctl
/etc/rc.d/mixer
/etc/rc.d/rctl
/etc/rc.d/netif
/etc/rc.d/devd
/etc/rc.d/resolv
/etc/rc.d/rtsold
/etc/rc.d/newsyslog
/etc/rc.d/virecover
/etc/rc.d/gptboot
/etc/rc.d/motd
/etc/rc.d/os-release
/etc/rc.d/cleartmp
/etc/rc.d/dmesg
/etc/rc.d/syslogd
/etc/rc.d/savecore
/usr/local/etc/rc.d/dbus
/etc/rc.d/utx
/etc/rc.d/ntpd
/etc/rc.d/sshd
/etc/rc.d/cron
/etc/rc.d/bgfsck
Edited by elliott9
@elliott9 Looks like you know a fair amount about unix like systems and how to poke around them.  UDI as a couple of applications that run and manage things.  You can check the log files for these.
/var/udx/logs/log
/var/udx/logs/debug.log
This service is what actually manages the updates.  If it had issues, it can leave things is a state where stuff just doesn't work.  In some cases, re-booting multiple times can get it to clean things up.
/var/isy/FILES/LOG is where the IoX log files are located.  There are a number of them.  One of these may help determine what's wrong.
Interesting that during the first days of the 5.9.1 update, no eisy's had problems. But now, what looks like two new, out of the box units have the same issue. Did anyone notice if they were running 5.8.4 when first powered up?
Add me to the list of an upgrade failure. Everything was working fine, did the upgrade package and after waiting around 45 minutes still can't get into anything. Tried a reboot. debug.log is showing this.
2025-03-08 20:51:04 -  DBG3|SysCall      [T:40422088974336] issuing system call /usr/local/etc/isy.d/static/isy_startup.sh (../src/Kernel/SystemCall.cpp@67:execOnly())
2025-03-08 20:51:04 -  Info|Config       [T:40422088974336] starting to parse file /var/isy/.env, delim = = (../src/Config/UDXConfig.cpp@20:parse())
2025-03-08 20:51:04 -  Info|UDXThread    [T:40422088974336] initializing (../src/System/UDXThread.cpp@494:init())
2025-03-08 20:51:04 -  Info|UDXThread    [T:40422088974336] setting scope to 2 successful (../src/System/UDXThread.cpp@186:setThreadScope())
2025-03-08 20:51:04 -  Info|UDXThread    [T:40422088974336] setting joinable to true for [0] (../src/System/UDXThread.cpp@229:setJoinable())
2025-03-08 20:51:04 -  Info|UDXThread    [T:40422088974336] setting joinable successful for [0] (../src/System/UDXThread.cpp@237:setJoinable())
2025-03-08 20:51:04 - Error|Config       [T:40422088974336] invalid value length (../src/Config/UDXConfigRecord.cpp@141:parse())
2025-03-08 20:51:04 - Error|Config       [T:40422088974336] could not add line:
IFS=
 (../src/Config/UDXConfigRecords.cpp@35:parse())
2025-03-08 20:51:04 -  Info|RunConfig    [T:40422088974336] changing directory to /var/isy (../src/System/UDXMain.cpp@135:main())
2025-03-08 20:51:04 -  Info|RunConfig    [T:40422088974336] the system is "eisy" v.5.9.1_11, running from /var/isy  (../src/System/UDXMain.cpp@143:main())
2025-03-08 20:51:04 - Error|RunConfig    [T:40422088974336] failed verifying signature (../src/System/UDXMain.cpp@147:main())
ok, was able to get mine back up and working. I ssh'd in and reran the package install.
sudo pkg install -f isy
then rebooted.
  • Like 1
  • Thanks 1
As mentioned in the instructions for upgrade, please do NOT reboot till you can get back to the unit. The upgrade is about 10GB of download, decrypt, extract, and install. During this process, the unit gets rebooted at least once. So pleased please please, if you don't have the patience to wait, do NOT upgrade.
If you're concerned that there's an issue with your upgrade, rather than rebooting please submit a ticket.
Yes, the upgrade might take more than one hour (and even two) depending on your network speed.
With kid regards,
With kid regards,
We'll it is peculiar to me to not offer the user any kind of progress tracking or logs to monitor. In absent of that it seems irresponsible to give a prompt that update could take up to half in hour if in reality it could take 2 hours.
My internet is plenty fast, it wouldn't take hours to download a 10g file to my PC, but I cannot speak to how the time would change on the eisy.
Seeing as how I can get to the Linux system, perhaps you can provide me file(s) I need and I can SCP them to the eisy myself and attempt a local install. Or do you have another recommendation?
Add me to the list of failed upgrades.  I was on 5.8 something.  I waited over an hour and nothing, so I rebooted.  Still nothing.  I had a backup so I could do a hard reset and reinstall, but I figured what the heck.  So, I connected up my monitor and executed the command listed above by cutthroat and that worked for me.
I love my eISY but I cringe and hold my breath every time I do an upgrade.   It is the only time I ever have issues.  I agree, some type of status should be available other than "it should take about 30 minutes".
Posted (edited)
Add me to the list of failed upgrades—I've had a 994 for about 10 years. I just got my EISY and it fired right up. I dutifully followed the instructions for migrating from the 994, which included a step to perform an upgrade. I saw a warning about waiting 30 minutes, but that it would continue to work. I clicked the upgrade button, and since then it has been unresponsive. I have since tried a factory reset (10 button presses), one button press for update, and five button presses for reboot. I have a 1G fiber internet connection, and my EISY is on the LAN, so it’s probably not a download speed issue. I also tried searching for the device using the mobile app, but had no luck. I can see both devices on my LAN. I tried https://192.168.0.193:8443/desc but received a refused to connect message. I guess I'll open a ticket as well—terrible new user experience.
Update: I logged in with PuTTY - SSH - so eisy is still somewhat functional  -  Guess I'll try install command.
Update:  Using Putty - SSH  - I tried these commands found in this forum and was able to bring the eisy back on-line.  Now I'm having issues with the serial PLM not connecting.
sudo pkg install -f udx
sudo tail -f /var/udx/logs/log ... wait till it either errors out (let me know the error) or successfully starts.
If successfully starts:
sudo shutdown -r now
After eisy rebooted, it was instantly recognized by phone and IoX finder.
Edited by tokenworker
You have the guide handy for a hard reset?
With kid regards,
I did not reboot my system until I got into the system via ssh and looked at the logs and saw the system crashing with core dumps.
Here is the log entry when the system auto rebooted.
Mar  8 20:31:31 eisy shutdown[74622]: reboot by udx_installer:
Below is when the system came up from the first reboot that the upgrade script did. This is the first log entry of the core dump, note time.
Mar  8 20:32:21 eisy kernel: pid 1723 (isy-freebsd-x64), jid 0, uid 349: exited on signal 11 (core dumped)
Mar  8 20:45:31 eisy kernel: pid 36451 (isy-freebsd-x64), jid 0, uid 349: exited on signal 11 (core dumped)
Mar  8 20:45:51 eisy kernel: pid 37202 (isy-freebsd-x64), jid 0, uid 349: exited on signal 11 (core dumped)
Mar  8 20:46:12 eisy kernel: pid 38065 (isy-freebsd-x64), jid 0, uid 349: exited on signal 11 (core dumped)
Mar  8 20:46:20 eisy reboot[38293]: rebooted by admin
I didn't reboot this system too soon. Note the 14-minute time gap with constant core dumps and when I rebooted it. The upgrade process failed. Are you saying the system should core dump constantly for 2 hours?
Please do not do that. Please submit a ticket. All these variations and factory reset and reinstall etc. will not help us find the root cause. Please please please submit a ticket.
For anyone having this issue, please note that the more you fiddle with files/services, the less the likelihood that you can recover. So, please do this:
1. Press/hold the power button -> red. Click again -> blue
2. If this does not solve the issue, please SUBMIT A TICKET. This is my last message on this topic.
  • Like 3
      38k
      379.6k
