I-Tach Node - Only One Button
Go to solution Solved by Javi,
I set up the nodeserver.  I followed the instructions to request the codes and copy and paste them all into the "Value" field.  When I go to the Admin Console, the device is working; however, I only have one choice under "Button Name".  Am I supposed to created new Custom Configurations for each button individually?  Based on the instructions, I was thinking I put them all under one configuration and would have the option to select the button from the drop down.
Reference https://github.com/JavierRefuerzo/iTach_IR_Node_Server?tab=readme-ov-file#general
Only one configuration is needed per device (not per code). Please post the value input into the node server, it's possible they changed the format so the Node Server cannot parse.  Being as there is only a single value the delimiter between codes may not match, if I remember correctly it is a double space or maybe a double new line.
      37.8k
      377.4k
