Repeating a certain program every 30 minutes
Go to solution Solved by paulbates,
Add a Repeat statement as the first statement under then. One of the options is "Repeat Every" set that to 30 minutes. The statements under Repeat will indent
Note that when the conditions of the If are no longer true, it will stop. In this program, it should bounce back and forth between then and else... which I think is your intent
Edited by paulbates
I did this before (every 10 minutes as a test) by adding to the THEN and ELSE statements....but when I looked in the SUMMARY TAB of the PROGRAMS TAB, and hit "refresh" I did not see the "Last finish time" or the "next Scheduled Run" had updated at all. Is this normal? Or should it have updated?
2 hours ago, ddeanwms said:
What I really want is for the entire program to run once an hour.
Ok, you'll need 2 programs
<Program 1> Computer Cabinet once an hour
   <no statement>
   Repeat every 1 hour
        Run If Program Computer cabinet
<Program 2> Computer Cabinet
    <your current program>
Notes:
  • Set the first program to run on start up
  • Disable program 2 so it does not run automatically
  • What this will do is the the ISY will run program 1 when its started
  • Program 1 will run once an hour
  • Program one will call program 2
  • Program 2 is disabled so it will only run when program 1 calls it
Edited by paulbates
