How/Where do I pay for the extended version?
Although I'm not really a novice using the eisy and developing routines that I want, This is the first time I've used a "Service".  I have it installed the product, and love it.  I want to purchase the "Standard version" ($15 one time charge) - as I'll want more than 8 notifications daily. I was using AT&T TEXT, which is now gone.  The notification service works perfectly for me as a substitute for email to text on AT&T.  If you can provide the instructions to pay for the standard version, I would surely appreciate it.
Solved by Geddy
Go to pg3x  and go to the production store, scroll down to the notification plug-in, click that and follow the directions
If you've not been to pg3x before, you can go into iox, click the plug-in menu and pick the bottom option to open pg3x. (You'll need to be on you local network in your house, not remote through the portal)
Take a look at the wiki too:
https://wiki.universal-devices.com/Eisy:User_Guide#Plugins_Store_Menu
You'll see the example window (for Blink not the Notification plugin). You should probably already be logged into the portal as part of the PG3x screen, but if not when you click purchase it should probably take you to the portal plugin then to the payment window.
