2411T won't link to ISY
Each time I've tried this, I factory reset the unit.
When I get to step 6 where it says to go back and repeat steps 1-5, then I double-tap the set button, but each time I tap it, it sends out the IR code that I taught it the first time around.
Then when I click "OK" in ISY, the nodes never show up.
One of my thoughts/concerns is: if this is a new 2411T that is factory reset, then how the heck does it know "who" my PLM is. Shouldn't I add the 2411T to the ISY before I add a button? If so, then this isn't anywhere in the descriptions that I have read about in other threads or in the wiki.
also, in the wiki there appear to be a mistake:
Learning and Testing an IR Code
1.Double-tap the Set button on IRLinc
IRLinc will double-beep and its LED will begin blinking
2.Point your IR remote control at the bottom of IRLinc, holding it within a couple inches of the IR sensor. Then, tap the IR button to be learned
IRLinc will double-beep, and its LED will turn on solid. If IRLinc beeps eight times, remount the IR emitter and start over from step 1.
3.Test that the IR code has been learned by double-tapping the Set button on IRLinc
IRLinc will beep
The IR emitters will blink red while the IR device responds to the IR command
If learning and testing was successful, you may continue installing or proceed to Linking.
this says to double-tap the button after the IR is sent to the 2411T to test it, but the ISY says just to tap it.
thanks,
someguy
and one more thing, if I'm not supposed to "link" the 2411T to the ISY outside of this "add a button" stuff, then why is the 2411T among the list of ISY devices that are listed that the ISY can link to in "new insteon device"?
thanks,
someguy
Not sure if this applies to the 2411T but for devices such as the EZSnsRF and EZX10RF which also have options under Link Management and I have defined to ISY, I added the devices to the ISY first using New Insteon Device. Then used the Link Management functions to add buttons/sensors/X10 codes to the respective devices which are displayed as additional Nodes. Adding the device first may be an unnecessary step but I did it for both the EZSnsRF and the EZX10RF devices. Also all codes do not have to be added at once. Being new to the ISY device, I added one Dakota Alert Sensor code and tested that. Then went back and added another Sensor code and tested that, and so on.
The 2411t that SH is selling doesn't work with the ISY. I understand they still have the older firmware model available that does work, but if you didn't specifically request it, you would have the new firmware.
As far as linking the 2411t, it doesn't link the unit per se, it links each infrared code almost as if it were its own device. So, no, you wouldn't linke the 2411t prior to linking IR codes.
The 2411T can be added in the Link Management Tab.
Add new Insteon/A10/X10 device.
If you don't auto discover it is 03.07 in the manual choices.
Though if there is a latest firmware problem in the 2411T not working. That could also be a problem.
I was able to get the ISY to connect to the 2411T using "new insteon device" on the third or fourth try and it says that the software version is v.49.
I bought this 2411T in November of last year. it says version 1.3 on the back of the unit.
Hello someguy,
I am glad that it worked. None of the new IRLinc TX firmware releases work with ISY and that's why SH has agreed to flash the older firmware (.49) for anyone requesting it.
I was able to connect the unit to the ISY using "New insteon device", but it does not work when I use "add new IR node to 2411T" (or whatever it is called.
Any further advice?
thanks,
someguy
Michel:
when I added the IRLinc 2411T itself as an insteon device, it took a very long time and there were many progress bars going across, but there was not a detailed explanation as to how to handle it, if that is what you mean by dialog.
Global cache is just awfully pricey and at first glance seems like it is rather complex. When you think that your are already spending $369 for the ISY, then another $50 for the module, and I think like $250 for the global cache, it just adds up to a lot of money to allow ISY to do what a $10 universal remote can do.
I mean one of the universal remotes that you can buy for a few bucks like this one.
http://www.buy.com/prod/xbox-360-univer ... 75285.html
It seems like you could purchase a ready made board from somewhere in China for a couple bucks each (bulk order) and integrate it directly into the isy board. Let the ISY send the commands to the IR control board that would otherwise come from a keypad.
  • 4 weeks later...
Hello someguy,
No, actually ISY should provide you with an instruction dialog on the steps required to link your 2411t.
I came back to this and here is how far I've gotten. I was able to get one node to show up in "my lighting", but there is no "current state", buttons or anything that could be done with this. Is that correct?
After I finish step 7 of "Add button to IRLinc Transmitter" (click OK), the node showed up, but then when I try to add another button by repeating the process, at step 1, I double press the set button on the 2411T and it sends the same code that I taught it the first time to my TV, just like it did on step 3 (the testing the code step) before. It seems as though my unit can't get past step 3, even though I press the button for 3 seconds (step 4) and wait for the beep (step 5).
Any ideas?
I'm using a brand new PLM and a "rev 1.3" 2411T.
thanks,
someguy
Hello someguy,
The problem is in the "brand new" ... unfortunately, you will have to ask SH to update your firmware to the previous release: there's a major problem reading the IR database with the new firmware.
Actually, it is my PLM that is "brand new".
My 2411T is from november of last year and it has software version .49, which is the old version, I believe.
I'm using 2.7.15.
Here is the events log:
Sat 08/14/2010 03:10:45 PM : Linked: Linked 0F.A6.64.00 type=03.07.49
Sat 08/14/2010 03:10:54 PM : ---- Initializing the linked devices ----
Sat 08/14/2010 03:10:54 PM : ---- All Linked Devices are now initialized ----
Sat 08/14/2010 03:10:54 PM : ---- Add remaining devices ----
Sat 08/14/2010 03:10:54 PM : [ F A6 64 1] Removing all links
Sat 08/14/2010 03:11:03 PM : [F A6 64 1 ] Searching for additional nodes in IRLinc Transmitter
Sat 08/14/2010 03:11:03 PM : [ F A6 64 1] Adding device to ISY t=03.07.4900
Sat 08/14/2010 03:11:05 PM : [F A6 64 1 ] IRLincTX addr=0x0010 .. Read [E0000F9DF3]
Sat 08/14/2010 03:11:06 PM : [F A6 64 1 ] IRLincTX addr=0x0010 .. Read [E0000F9DF35F1204]
Sat 08/14/2010 03:11:08 PM : [F A6 64 1 ] IRLincTX addr=0x0018 .. Read [122004740DB70473]
Sat 08/14/2010 03:11:10 PM : [F A6 64 1 ] IRLincTX addr=0x0020 .. Read [0DB7047304910473]
Sat 08/14/2010 03:11:11 PM : [F A6 64 1 ] IRLincTX addr=0x0028 .. Read [0DB704730DB70473]
Sat 08/14/2010 03:11:13 PM : [F A6 64 1 ] IRLincTX addr=0x0030 .. Read [0DB704730DB70473]
Sat 08/14/2010 03:11:26 PM : [F A6 64 1 ] IRLincTX addr=0x0038 .. Read [0DB8047304920472]
Sat 08/14/2010 03:11:27 PM : [F A6 64 1 ] IRLincTX addr=0x0040 .. Read [0DB8047204920472]
Sat 08/14/2010 03:11:29 PM : [F A6 64 1 ] IRLincTX addr=0x0048 .. Read [0493047204930472]
Sat 08/14/2010 03:11:30 PM : [F A6 64 1 ] IRLincTX addr=0x0050 .. Read [0DB8047204930472]
Sat 08/14/2010 03:11:32 PM : [F A6 64 1 ] IRLincTX addr=0x0058 .. Read [0493047204930471]
Sat 08/14/2010 03:11:34 PM : [F A6 64 1 ] IRLincTX addr=0x0060 .. Read [0493047104930471]
Sat 08/14/2010 03:11:35 PM : [F A6 64 1 ] IRLincTX addr=0x0068 .. Read [0DB9047104940471]
Sat 08/14/2010 03:11:39 PM : [F A6 64 1 ] IRLincTX addr=0x0070 .. Read [0DB90471CAA4FFCD]
Sat 08/14/2010 03:11:41 PM : [F A6 64 1 ] IRLincTX addr=0x0078 .. Read [004111D7124B0446]
Sat 08/14/2010 03:11:42 PM : [F A6 64 1 ] IRLincTX addr=0x0080 .. Read [0DE404160040FFCE]
Sat 08/14/2010 03:11:45 PM : [F A6 64 1 ] IRLincTX addr=0x0088 .. Read [0DFDFFD60040FFD3]
Sat 08/14/2010 03:11:46 PM : [F A6 64 1 ] IRLincTX addr=0x0090 .. Read [004000790040FFCF]
Sat 08/14/2010 03:11:47 PM : [F A6 64 1 ] IRLincTX addr=0x0098 .. Read [0040FFCF0040FFCF]
Sat 08/14/2010 03:11:49 PM : [F A6 64 1 ] IRLincTX addr=0x00A0 .. Read [0040FFCD0040FFCF]
Sat 08/14/2010 03:11:50 PM : [F A6 64 1 ] IRLincTX addr=0x00A8 .. Read [0040FFCD0040FFCD]
Sat 08/14/2010 03:11:52 PM : [F A6 64 1 ] IRLincTX addr=0x00B0 .. Read [0040FFCD0040FFCD]
Sat 08/14/2010 03:12:04 PM : [F A6 64 1 ] IRLincTX addr=0x00B8 .. Read [0040FFCD0040FFCD]
Sat 08/14/2010 03:12:06 PM : [F A6 64 1 ] IRLincTX addr=0x00C0 .. Read [003BFFDD0040FFCF]
Sat 08/14/2010 03:12:08 PM : [F A6 64 1 ] IRLincTX addr=0x00C8 .. Read [0040FFCF0040FFCE]
Sat 08/14/2010 03:12:12 PM : [F A6 64 1 ] IRLincTX addr=0x00D0 .. Read [0040FFCD0040FFCD]
Sat 08/14/2010 03:12:14 PM : [F A6 64 1 ] IRLincTX addr=0x00D8 .. Read [0040FFCD0040FFCD]
Sat 08/14/2010 03:12:18 PM : [F A6 64 1 ] IRLincTX addr=0x00E0 .. Read [0040FFCD0040FFCD]
Sat 08/14/2010 03:12:19 PM : [F A6 64 1 ] IRLincTX addr=0x00E8 .. Read [0040FFCD0040FFCD]
Sat 08/14/2010 03:12:21 PM : [F A6 64 1 ] IRLincTX addr=0x00F0 .. Read [0040FFCD0040FFCD]
Sat 08/14/2010 03:12:22 PM : [F A6 64 1 ] IRLincTX addr=0x00F8 .. Read [0040FFCD0040FFCD]
Sat 08/14/2010 03:12:23 PM : [F A6 64 1 ] IRLincTX addr=0x0100 .. Read [0040FFCD0040FFCD]
Sat 08/14/2010 03:12:25 PM : [F A6 64 1 ] IRLincTX addr=0x0108 .. Read [0040FFCD0040FFCD]
Sat 08/14/2010 03:12:28 PM : [F A6 64 1 ] IRLincTX addr=0x0110 .. Read [003BFFCD003BFFCD]
Sat 08/14/2010 03:12:29 PM : [F A6 64 1 ] IRLincTX addr=0x0118 .. Read [0045FFCD0042FFD8]
Sat 08/14/2010 03:12:42 PM : [F A6 64 1 ] IRLincTX addr=0x0120 .. Read [0004E0FFD00041FF]
Sat 08/14/2010 03:12:44 PM : [F A6 64 1 ] IRLincTX addr=0x0128 .. Read [0040FFCD0040FFCD]
Sat 08/14/2010 03:12:45 PM : [F A6 64 1 ] IRLincTX addr=0x0130 .. Read [0040FFCD0045FFDB]
Sat 08/14/2010 03:12:46 PM : [F A6 64 1 ] IRLincTX addr=0x0138 .. Read [0041FFCE0040FFCD]
Sat 08/14/2010 03:12:49 PM : [F A6 64 1 ] IRLincTX addr=0x0140 .. Read [0040FFCD003BFFCD]
Sat 08/14/2010 03:13:01 PM : [F A6 64 1 ] IRLincTX addr=0x0148 .. Read [0044FFDA0043FFCE]
Sat 08/14/2010 03:13:02 PM : [F A6 64 1 ] IRLincTX addr=0x0150 .. Read [0040FFCD0040FFCD]
Sat 08/14/2010 03:13:04 PM : [F A6 64 1 ] IRLincTX addr=0x0158 .. Read [003BFFCD0044FFCD]
Sat 08/14/2010 03:13:05 PM : [F A6 64 1 ] IRLincTX addr=0x0160 .. Read [0041FFD70043FFCE]
Sat 08/14/2010 03:13:09 PM : [F A6 64 1 ] IRLincTX addr=0x0168 .. Read [0041FFCD0040FFCD]
Sat 08/14/2010 03:13:11 PM : [F A6 64 1 ] IRLincTX addr=0x0170 .. Read [003BFFCD0044FFCD]
Sat 08/14/2010 03:13:15 PM : [F A6 64 1 ] IRLincTX addr=0x0178 .. Read [0041FFD70044FFCE]
Sat 08/14/2010 03:13:16 PM : [F A6 64 1 ] IRLincTX addr=0x0180 .. Read [0042FFCD0040FFCD]
Sat 08/14/2010 03:13:17 PM : [F A6 64 1 ] IRLincTX addr=0x0188 .. Read [003BFFCD0044FFCD]
Sat 08/14/2010 03:13:22 PM : [F A6 64 1 ] IRLincTX addr=0x0190 .. Read [0041FFD70045FFCD]
Sat 08/14/2010 03:13:24 PM : [F A6 64 1 ] IRLincTX addr=0x0198 .. Read [0042FFCD0040FFCD]
Sat 08/14/2010 03:13:25 PM : [F A6 64 1 ] IRLincTX addr=0x01A0 .. Read [0047FFCD0044FFCD]
Sat 08/14/2010 03:13:27 PM : [F A6 64 1 ] IRLincTX addr=0x01A8 .. Read [0041FFD60046FFCD]
Sat 08/14/2010 03:13:40 PM : [F A6 64 1 ] IRLincTX addr=0x01B0 .. Read [0042FFCD0040FFCD]
Sat 08/14/2010 03:13:44 PM : [F A6 64 1 ] IRLincTX addr=0x01B8 .. Read [0046FFCD0043FFCD]
Sat 08/14/2010 03:13:45 PM : [F A6 64 1 ] IRLincTX addr=0x01C0 .. Read [0040FFCD0DF6FFCF]
Sat 08/14/2010 03:13:46 PM : [F A6 64 1 ] IRLincTX addr=0x01C8 .. Read [0041FFCE0040FFCD]
Sat 08/14/2010 03:13:48 PM : [F A6 64 1 ] IRLincTX addr=0x01D0 .. Read [0040FFCD003BFFCD]
Sat 08/14/2010 03:13:52 PM : [F A6 64 1 ] IRLincTX addr=0x01D8 .. Read [0044FFD90043FFCE]
Sat 08/14/2010 03:13:53 PM : [F A6 64 1 ] IRLincTX addr=0x01E0 .. Read [0040FFCD0040FFCD]
Sat 08/14/2010 03:13:55 PM : [F A6 64 1 ] IRLincTX addr=0x01E8 .. Read [003BFFCD0044FFCD]
Sat 08/14/2010 03:13:56 PM : [F A6 64 1 ] IRLincTX addr=0x01F0 .. Read [0041FFD70044FFCE]
Sat 08/14/2010 03:13:57 PM : [F A6 64 1 ] IRLincTX addr=0x01F8 .. Read [0041FFCD0040FFCD]
Sat 08/14/2010 03:13:59 PM : [F A6 64 1 ] IRLincTX addr=0x0200 .. Read [003BFFCD0044FFFF]
Sat 08/14/2010 03:14:00 PM : [F A6 64 1 ] IRLincTX addr=0x0208 .. Read [CB00000000000000]
Sat 08/14/2010 03:14:00 PM : [0F.A6.64.1] Start : Adding device to ISY
Sat 08/14/2010 03:14:00 PM : [0F.A6.64.1] Finish : Adding device to ISY was Successful
Sat 08/14/2010 03:14:02 PM : [F A6 64 1 ] IRLincTX addr=0x0210 .. Read [0000000000]
Sat 08/14/2010 03:14:02 PM : [F A6 64 1 ] Start Moving High Water mark for IRLinc Transmitter Code database
Sat 08/14/2010 03:14:02 PM : [F A6 64 1 ] Finish (Success) Moving High Water mark for IRLinc Transmitter Code database
Sat 08/14/2010 03:14:03 PM : ---- All Remaining Device Added ----
Sat 08/14/2010 03:14:03 PM : [F A6 64 1 ] IRLincTX addr=0x0010 .. Write [0000000000000000]
This DID create a node in "My Lighting":
but there are two problems. One is that there doesn't appear to be any way to use this. How do I use this.
The other is: after getting this node in there, each time I press the button on the 2411T to create another node (or couble-tap it), it sends the last remote code to the TV.
The Event Log does not look like it was set for level 3 but since it says success that may not be needed. Are you using the Link Management | Add Button to IRLinc Transmitter to add additional nodes.
