bmercier Posted June 18 Author Posted June 18 24 minutes ago, MWoods329 said: One day, I will have an intelligent question to post here. Maybe that day is today? Anyway... I'm curious why I can't take a dimmer on a Hue light down to zero? That means I'd need to have two tiles to handle the dimming on these. Or is there a better way to make the slider both dim and turn it off? I know that's a limitation in the admin console, I guess I just would have expected a more user-friendly UI would handle those types of interactions. This is still just a beta. Will enhance this. For now, just edit the tile and add a switch widget. 1 Quote
sjenkins Posted June 21 Posted June 21 @bmercier Not sure if its on your known todo list but with the new eisyui service running.... I CANNOT save a program change in the AC when running it from port 80 with the portal credentials. I can edit but it will not save. Sometimes a pop-up with a save message comes up but usually not. I CAN edit and save in the AC if I run it using port 8443 and local credentials. Again, both are with the eisyui service running. 2 Quote
TJF1960 Posted June 22 Posted June 22 I have experienced the same problem as @sjenkins with saving programs when using anything but port 8443. I have also experienced a couple of random, reboots. As well as random plugins failing and restarting and notices about the portal being offline. I have also had Alexa complain that the "hub" is offline when asking her to turn on ISY devices and programs. These things are not frequent and unfortunately by the time I get to log in to download logs they have already refreshed. I was hoping others were having the same issue but it looks like my experience may be a one-off. Quote
sjenkins Posted June 22 Posted June 22 1 hour ago, TJF1960 said: I have experienced the same problem as @sjenkins with saving programs when using anything but port 8443. I have also experienced a couple of random, reboots. As well as random plugins failing and restarting and notices about the portal being offline. I have also had Alexa complain that the "hub" is offline when asking her to turn on ISY devices and programs. These things are not frequent and unfortunately by the time I get to log in to download logs they have already refreshed. I was hoping others were having the same issue but it looks like my experience may be a one-off. sorry @TJF1960 , I am not having reboots, portal, or Alexa issues Quote
bmercier Posted June 23 Author Posted June 23 @sjenkins, @TJF1960, Thanks for reporting the problem with saving programs. I reproduced it in dev and will release it in the next hour or so. On 6/22/2025 at 10:41 AM, TJF1960 said: I have experienced the same problem as @sjenkins with saving programs when using anything but port 8443. I have also experienced a couple of random, reboots. As well as random plugins failing and restarting and notices about the portal being offline. I have also had Alexa complain that the "hub" is offline when asking her to turn on ISY devices and programs. These things are not frequent and unfortunately by the time I get to log in to download logs they have already refreshed. I was hoping others were having the same issue but it looks like my experience may be a one-off. The program save issue is resolved in dev. The other issues you are having are not related to eisy-ui. I would encourage you to open a ticket. Quote
GTench Posted June 23 Posted June 23 @bmercier still not seeing icons under favorites for Yolink devices with eisyui-0.5.1.pkg . Node listing says they are connected Quote
sjenkins Posted June 23 Posted June 23 (edited) thanks @bmercier , Lots of good stuff here in 0.5.1. !! note for everyone: I did have to clear the cache to get the new version to load in my browser 😀 New Portal Authorisation page under Settings 😀 Login with no connectivity ❓ icon search with synonyms (not sure what this is) 🤫 Nodes page: Added folders - (they keep closing ; need memory like AC) 😀 Nodes page: Display names in the tree instead of the address 🚫 Fix for Yolink (still blank detail screens) 😀 Dimmers can now send a DOF when turned to 0 😀 Admin Console save function is fixed Edited June 23 by sjenkins make clear 0.5.1 Quote
bmercier Posted June 23 Author Posted June 23 15 minutes ago, sjenkins said: thanks @bmercier , Lots of good stuff here in 0.5.1. !! note for everyone: I did have to clear the cache to get the new version to load in my browser 😀 New Portal Authorisation page under Settings 😀 Login with no connectivity ❓ icon search with synonyms (not sure what this is) 🤫 Nodes page: Added folders - (they keep closing ; need memory like AC) 😀 Nodes page: Display names in the tree instead of the address 🚫 Fix for Yolink (still blank detail screens) 😀 Dimmers can now send a DOF when turned to 0 😀 Admin Console save function is fixed icon search: This was following this post by @bpwwer: Now you should be getting a lot more results when searching for a keyword. Nodes page: Added folders - (they keep closing ; need memory like AC) Will look into that Fix for Yolink (still blank detail screens) I removed it from the feature list of 0.5.1. It will be permanently fixed with the next IoX release. 37 minutes ago, GTench said: @bmercier still not seeing icons under favorites for Yolink devices with eisyui-0.5.1.pkg . Node listing says they are connected I removed it from the feature list of 0.5.1. It will be permanently fixed with the next IoX release. It should not have made it to that list. 1 Quote
MWoods329 Posted June 25 Posted June 25 Upgraded to 0.5.1 and now I can't even save a dimmer tile Config: Widget Config: Quote
bmercier Posted June 25 Author Posted June 25 9 minutes ago, MWoods329 said: Upgraded to 0.5.1 and now I can't even save a dimmer tile Config: Widget Config: Please check what the log says when you save. Also, are you sure Set Brightness is the right command? Quote
sjenkins Posted July 7 Posted July 7 Tried out 0.5.3 You can see it developing, step-by-step, I like the node icons. It crashed once on me with a message about compressing, but I couldn't get it to repeat. I will document next time. If you compress any groups/folders then select a node it immediately uncompresses (assuming reloading the whole list), this means that you lose where you are in the list. I think you mentioned before that an ISY update was needed to fix this & get it to remember when you open/close a folder/group? Just ignore me for now if this is in the pipeline. Quote
bmercier Posted July 7 Author Posted July 7 9 minutes ago, sjenkins said: If you compress any groups/folders then select a node it immediately uncompresses (assuming reloading the whole list), this means that you lose where you are in the list. That's a regression bug. I made many changes that are not visible, and obviously this broke the folder compressed/uncompressed persistence. Will fix this in the next release. 1 Quote
sjenkins Posted July 8 Posted July 8 (edited) 19 hours ago, bmercier said: That's a regression bug. I made many changes that are not visible, and obviously this broke the folder compressed/uncompressed persistence. Will fix this in the next release. Version 0.5.4 Thanks for the fix on the folder memory, checks out. Maybe for the TODO list. One nice feature of the AC was the ability to click on a node then to move up/down the list with cursor, opening and closing folders with left/right. For us old school keyboarders (I am known for using Emacs) that was really nice. Edited July 8 by sjenkins Quote
BamBamF16 Posted July 8 Posted July 8 (edited) Folder auto opening is fixed. Clicking on Node column to sort does not. Just a random sort order. Consistently the same incorrect order. Edited July 8 by BamBamF16 Quote
bmercier Posted July 9 Author Posted July 9 14 hours ago, BamBamF16 said: Folder auto opening is fixed. Clicking on Node column to sort does not. Just a random sort order. Consistently the same incorrect order. Thanks for reporting this. Actually, the sort order is not random, it's sorted using the node address, which is not displayed in this column. This will be fixed in the next release. Quote
paulbates Posted 2 hours ago Posted 2 hours ago Is there a rough estimate for when eisy-us alpha/beta will be available as an update, not an SSH download? That's when I'll start joining the testing Quote
bmercier Posted 2 hours ago Author Posted 2 hours ago It already is. However, the currently published one is 0.5.4. 0.5.5 will be next week. 1 Quote
bmercier Posted 36 minutes ago Author Posted 36 minutes ago 1 hour ago, paulbates said: Upgrade packages? Yes that’s what I mean by published Quote
