Bandy Posted June 11 Posted June 11 I bought another ISY 994I to see if it was the 994i IR pro that was causing me some issues after years of perfection. The new one has Zwave. It is 4.6.2 firmware. any chance of getting 5.3.4 and buying another X-10 module? Quote
Guy Lavoie Posted June 11 Posted June 11 (edited) If it doesn't already have the X10 module, you can't add it anymore. If you want to stick to a ISY994i, you'll need to find a used one that already has any modules you want. Edited June 11 by Guy Lavoie Quote
Brian H Posted June 11 Posted June 11 Depending on the ZWave module installed. You maybe limited to firmware revision you can install. No personal information but you maybe able to remove it and install the last firmware released for the ISY994i The X10 module is gone as Guy pointed out. I got lucky. When the ISY994i was announced being discontinued but still available. I bought the X10 and Pro updates for my spare basic ISY994i. Quote
paulbates Posted June 11 Posted June 11 Didn't all the 994is have basic x10 capability? I think the module added the ability for extended x10 codes naming nodes versus HC/UC Depending on what features you're using, it could work with potentially some basic programming changes. Plug in the backup unit and see how it would work for you programming wise as well as test to see if perfection returns 1 Quote
Brian H Posted June 11 Posted June 11 32 minutes ago, paulbates said: Didn't all the 994is have basic x10 capability? I think the module added the ability for extended x10 codes naming nodes versus HC/UC Depending on what features you're using, it could work with potentially some basic programming changes. Plug in the backup unit and see how it would work for you programming wise as well as test to see if perfection returns Yes they do basic X10 without the A10/X10 module added. I have it but never used it. As the added goodies where not needed or used. Thank you for jogging my memory. Quote
Guy Lavoie Posted June 11 Posted June 11 Yes, the X10 module was mostly a convenience, allowing you to add X10 devices to your device list. It would still be handy to a user who is looking to replace a defective unit and recover from a backup, without needing to edit all the programs. Quote
Bandy Posted Wednesday at 09:00 PM Author Posted Wednesday at 09:00 PM So the "module" was nothing more than flipping a switch with some code for $50: nobody? Ha. I remember sending boxes of brown X-10 modules to BSR in New Jersey and getting a few new ones in a swap. Kinda warm and fuzzy. The engineers at Digital in Mass who made the Enerlogic were amazing but quit quickly. I have an ocelot somewhere, I have one of those big *** expensive panels somewhere. I visited Smart Home in Irvine many times and always came away with a creepy feeling about the company and was not surprised when they flipped the switch on insteon users. I have always hated everything RF because of the stupid FCC 10 milliwatt limit. I met with people at FCC in Washington in the 1970s and realized why the lazy people did it so low. That level shifted complaints from FCC to manufacturers. 50mw and the stuff would have worked. I liked that insteon was powerline and RF. So had someone directed me to somewhere in UD land where I was offered a way to set up X10 in the replacement ISY for temporary I would be inclined to research and buy one of the new polygamy devices and take life easy. Sensing the grifter vibe I am off to waste a few thousand hours on an HA system. So I had a Belgian waffle and then watched the GE carousel of progress in NY. Later my next door neighbor described a system that would send a signal to a light to turn it on and off. I had just figured out circuits and thought he was crazy. The tenth LSI was made in Scottland about twelve years later. Those were some bright people who made that. If they only knew that the future was just around the corner.....well, a very long and convoluted corner..-30- Quote
