UD Mobile - ThirdReality T&H Sensor
@Javi while technically not a UDM question, I'm curious to know why the battery level doesn't display as it does in Home Assistant?
Also, I'm using status charting and I find it to be a very useful feature.  It says beta, are there still plans to make it production?
Update: not sure why it's reading AM, should be PM.
thumbnail_Screenshot2025-07-26at1_07_16PM.thumb.jpg.5d000cd9facba8571f014a7bc6e8e2e4.jpg
Edited by mmb
If your device is battery powered it most likely only sends the battery level every 12 0r 24 hours. Until then the battery status will be blank
Thanks @Techman, the battery power showed quickly using HA.
I’ll check it tomorrow.
Edited by mmb
Update, I went back to Home Assistant. Graphs and battery levels work properly. I'll just use it until things are sorted out on IoX.Screenshot2025-07-28091148.thumb.png.28aa99ef064c7ed958934184858a32c7.png
Not sure, is there sibling node with the battery level?
The time is one of the reasons it's still beta, we had a formatting issue in the database. I think it should be fixed in the next firmware release, but not my specialty so I could be wrong .  We also still need to implement a database  purging as the database could become very large very quickly for some users.
Yes, there is a bundled battery entity.Screenshot2025-07-29084301.thumb.png.e523b61502942b0ab8c666067f7f00b7.png
Thanks for the update.
I see, no separate power node.
I did check for it as I do have other devices that have power nodes.
