FarmerGeek Posted August 5 Posted August 5 Finally moving to eisy from my old isy994i. I need to connect to my ELK security panel. Tried to load the ELK plugin and got Error 404. Then tried to load the AmbientWeather plugin. also got error 404. What could I have missed? Quote
DennisC Posted August 6 Posted August 6 5 hours ago, FarmerGeek said: Tried to load the ELK plugin Tried to load from where? Are you saying you received this message when you navigate to PG3x? PG3x is available by entering your IP address and port 3000. Quote
FarmerGeek Posted August 6 Author Posted August 6 From the start. I use IoX finder to bring up Poyglot 3. click on the Plugins Store. Scroll down to the Elk plugin. When I click on the Elk plugin I am directed to the IP address of the eisy address port 3000. That is when I get the error. Quote
DennisC Posted August 6 Posted August 6 33 minutes ago, FarmerGeek said: From the start. I use IoX finder to bring up Poyglot 3. click on the Plugins Store. Scroll down to the Elk plugin. When I click on the Elk plugin I am directed to the IP address of the eisy address port 3000. That is when I get the error. It sounds like to me you are not logged in to PG3. Let's try this: In your browser type the IP address of your eisy followed by :3000 (xxx.xxx.x.xxx:3000). This should open up PG3. Login to PG3 using your eisy login info. Go to top menu and select IoX Configuration. If eisy is registered with PG3, you should see your eisy uuid number with a check mark (might be greyed out or lighter color). If that all checks out, click tab for Plugins Store, followed by Elk Plugin. Quote
FarmerGeek Posted August 6 Author Posted August 6 Had to register than log completely out and back in and I am in. Thanks. Now, the reason I wanted the plug in is I use it in scripts in isy994. For example, if the alarm goes off the isy turns on all the outside lights and some of the inside lights. Is this even possible? if it is, please point me the info on how. Quote
DennisC Posted August 6 Posted August 6 12 minutes ago, FarmerGeek said: Had to register than log completely out and back in and I am in. Thanks. Now, the reason I wanted the plug in is I use it in scripts in isy994. For example, if the alarm goes off the isy turns on all the outside lights and some of the inside lights. Is this even possible? if it is, please point me the info on how. Glad you got in. Go back to PG3, Plugin Store, Elk, and then click on "more info" button. That will take you to GitHub and plenty of examples on how to use the Plugin. Quote
FarmerGeek Posted August 6 Author Posted August 6 Looks like I have a lot to lean. I see the code. Where/how do I apply the code? Quote
DennisC Posted August 6 Posted August 6 2 hours ago, FarmerGeek said: Looks like I have a lot to lean. I see the code. Where/how do I apply the code? You would need to create the programs on your eisy, using the names of your devices. It sounds like you are asking for basic information, like how to create a program? If so, I am providing links for various resources on how to get started with UD's systems. The documentation may be for the ISY994, however, the main principles are the same. https://wiki.universal-devices.com/index.php?title=Main_Page#ISY_Cookbook https://wiki.universal-devices.com/index.php?title=Main_Page#Complete_and_Comprehensive_User_Guides https://wiki.universal-devices.com/Main_Page Quote
DennisC Posted August 6 Posted August 6 Here is one more on the Elk plugin: https://docs.google.com/document/d/19uqu-jYmgxrkhhxn9YYeALRhC8mVBK2F0L589g-YU28/mobilebasic Quote
