PLM / Not Connected ??? (2413U)
jim_
Everything was running fine until dusk tonight, then no lights turned on at dusk.   After a short trouble shooting exercise, checked tools / diagnostics / PLM info / status => (Not Connected)
Factory reset the PLM, changed the USB cable to new, swapped the PLM and Zmatter USB ports (power cycled EISY for each change) ...  PLM remains Not Connected
Where can I see an OS message that shows USB device status ?  or log message that documents PLM failure ?
NOTE  :  The EISY is always popping up "System Busy" do not unplug ...  the pop-ups have no information and and take 20+ minutes to close after each reboot
Assuming the 2413U is dead , ordering one will take many weeks to obtain where I live ... (Thanks Mr Trump)
How do I go back to my 994 ?   98% of the config would be identical ... I have 95% insteon and 5% zwave
Is there go back guide ?
What are your firmware and UI versions?
On your configuration tab, is Insteon support checked
The USB PLMs are back ordered and not expected to be available until November
Edited by Techman
You mention going back to the ISY994... do you have a separate PLM for it? If yes, it might be simpler and faster to get a USB to serial adapter for it, and use that to connect it to your eisy.
Thanks for the tip Techman,  Insteon was NOT checked ...
Now, how does an option mysteriously change?  I checked and found the last time I logged into eiesy was Aug 14 ... so exactly how does an option that was set 2 years ago become un-checked ?
Fast forward, every Insteon device was NOT responding once the PLM showed connected. After many hours of manually Restoring Devices or Write updates to each device ... eI now have every Insteon device back on line execpt for 1 motion (2844). Some were extremely stubborn particularly 3 or 4 way slave switches.
Scenes that involve a KPL work, example garage door opener via KPL button or a 3 / 4 way light switch. BUT anything involving programs will NOT run. Some programs show true status, others show no change in status when something is triggered.
My nightly dusk program just started,  none of the lights in program are turning on e.g. Kitchen Sink. From admin console, I can turn the Kit light on / off no issues.
Anything with timers will not run ... e.g.
Fireplace Fan Timer
        'Fireplace Fan 4F.E4.85' Status is On
        Wait  1 minute
        Set 'Fire Place Fan' Off
I created a new timer, using a test switch and it works
AAA test
        'AAA Test Switch' Status >= 1%
        Wait  10 seconds
        Set 'AAA Test Switch' Off
I'm completely confused on how to debug this issue
I opened a ticket ...
I just found a new twerk ... all switches can be controlled by the admin console, but if you manually turn on / off a switch, the console never see's the state change. Watching the event viewer ... manual changes are not logging
Edited by jim_
You said you factory reset the PLM.
So it was cleaned out of all information and you had to restore all the data.
Edited by Brian H
@jim_
Not sure how your insteon support became unchecked. It's possible that you may have accidentally clicked it. At least you're back in business without having to buy a PLM
As @Brian H mentioned, a factory reset on your PLM erased all it's data. What you needed to do was a "Restore PLM"  assuming you have a viable and current backup.
After you get everything working be sure to do both an ISY backup and a Zwave backup
Here's the restore PLM info:
Click on the Battery icon at the top. This will prevent EISY from trying
to update programming on your RF devices which are probably in sleep
mode
Click on the Restore Modem (PLM) menu option
In case EISY cannot communicate (or decides not to if it’s an RF device
during the process, you will have a series of nodes with green 1011 icons in
the device tree. For each one of those nodes:
If an RF device, ensure that the device is in Programming mode (awake)
Right mouse click | Write pending updates
If the above procedure fails on many of your devices, it's highly recommended that you
follow the instructions for Restore Devices.
  • Thanks 1
Thanks everyone for your support
Long story short, been chatting with Michel ... I'm screwed ... Michel may look later on why Insteon support magically became unchecked.
We (family) lost our virtual (internet) backup drive back in the summer which had all my backups, so lesson learned, now have NAS on site for all our auto backups.
So restoration the hardway has begun
I'm an INSTEON installer and am at a customer who has the same scenario described above.
I assumed the PLM dead. Replaced it, no change.
Found this thread.
INSTEON support was unchecked. Checked it, saved, restarted IOX.
PLM working.
I'm going the check my other eisy customers.
Thanks for this thread!
