Insteon Leak Sensor 2852-222 Programs
I have had several leaks under my kitchen sink (new home) connected to a new Insinkerator disposal that I think have finally been resolved with a new, more substantial o-ring. To be sure that there is no damage in the future, I have ordered the leak sensor. The problem is the drain, not the hot/cold water input, so I don't need to connect up water shutoff valves.
I'm not sure what kind of programming/notification I want to create. Anyone have any programs that they have successfully used for notification, or any other ideas?
BTW, I had several of these sensors in my old home, but those were ISY, not EISY, days and more than 10 years ago. Long lost...
Ty!
I have several Insteon leak sensors. I have them shut off the water (Watercop valve) and send me a notification email. I also get notifications for missed heartbeats.
I have 3 leak sensors that cover my hot water tank, sump pump area and well. I have them set up 3 ways
1- There are linked via a scene to an Insteon chime module in the house so it "screams" if any of them go off
2- I have a program that sends a specific notification for each one. I use the paid for notification plugin and get the notifications via push over, but you can do email, text etc
Well - Wet - [ID 0014][Parent 000E]
'Leak Sensors / Well Wet' is switched On
Set 'Notifications / Service Pushover alerts' Send Sys Custom With Params Priority=Emergency Sound=Siren Retry=30 Expire=60 Content 7 Notification ID (ID=7)
3- I also have a program that tracks the once-a-day heartbeat message from the leak sensor. If it stops coming, the leak sensor battery is dead and I want to know:
Well Heartbeat - [ID 0010][Parent 0032]
'Leak Sensors / Leak Sensor Battery / Well Heartbeat' is switched On
Or 'Leak Sensors / Leak Sensor Battery / Well Heartbeat' is switched Off
Wait 25 hours
Set 'Notifications / Service Pushover warnmsg' Send Sys Custom With Params Priority=Normal Sound=Vibrate Only Retry=30 Expire=60 Content 4 Notification ID (ID=4)
The 25 hour wait is because if the message comes once a day, the program restarts. If the battery dies it doesn't send an
@haroldunger I ran Insteon leak sensors years ago and remember these two threads helping...they might be way overkill, but worth reviewing in your situation.
I've since changed to YoLink leak sensors and they work great with the eisy+yolink plugin and (really just the YoLink app) for alerts. But I use YoLink for several other things so already had a hub and the plugin.
Check these out:
Ty to all. Will review the suggestions, key in on one, and try to implement it.
Well, the sensor (2852-222 version 3.0 2724) arrived, and I installed it into the Eisy program.
Post installation, I now have three devices:
Device 1: xx.xx.xx.1 Dry
Device 2: "Kitchen Sink (my name)".2, the #2 automatically showed up
Device 3: "Kitchen Sink (my name)".4, the #4 automatically showed up
I have started to set up programs that cause an email to be sent for the heartbeat and any potential leak.
But, I'm not sure why there are three devices. Can someone help here, please?
Thanks.
Edited by haroldunger
I'm not sure why the designers thought is was necessary, but there is one node for a dry state and one for a wet state... and they are always the opposite of each other. There's also one for the heartbeat. Typically wet and dry are both labled so that leaves the heartbeat. I'm taking a guess that your naming scheme "overran" the amount of space for the wet/dry names, but it seems wet and dry should both fit (?)
Unless someone else has a better idea, you might have to delete it from the ISY and re-add it without renaming... both the wet and dry names should be there. Then rename them once you know which is which
Edited by paulbates
The names for xxx.2 and xxx.4 were identical except for the numbers. I definitely would have made a note of the original names had they been different.
I do have a contact at Insteon that might be able to shed some light on the module. Perhaps I should send him an email?
Check these out:
I too switched to Yolink leak sensors as well from the Insteon leaks, got the hub and connected to EISY. Still have some Insteon Leaks though as well.
Yolink makes great leak and temp sensors. I will look at getting their other sensors as needed as they are rock solid.
Ty, paulbates. I will uninstall and reinstall the sensor. JUST UNINSTALLED/REINSTALLED. YOU'RE CORRECT. I MESSED UP AND OVERWROTE THE NAMES. MY BAD!!!!
Also, I'm awaiting a response to my email to my Insteon contact. Somehow, I don't remember the original 2852-222 as being this complicated to program. Maybe, it's my age...
From my buddy who consults for Insteon (caveat - older sensors might be different):
For most EISY setups, “wet” corresponds to ON, and “dry” corresponds to OFF. The heartbeat node reports the sensor’s status to confirm communication, typically every 24 hours. The EISY will display “yes” when the heartbeat is received; if it hasn’t seen one in that period, it’ll switch to “no.”
When the sensor detects moisture, wet → ON and dry → OFF. Once it’s been triggered (wet), you must tap the set button several times to manually reset it to normal operation. This is a safety behavior — the device won’t automatically return to “dry” after getting wet, since floating debris or position changes could falsely suggest the water issue is resolved.
During testing, you may notice it doesn’t automatically reset — that’s expected until you press the set button to acknowledge the condition.
