Creating a button to run Then statement in a program
Is it possible to create a button in UD Mobile to execute the then statement in a program. I am running the Harmony plugin and have several streaming services on my home screen of the TV. I can go to my programs in UD Mobile and run the then sttement but I would like to make is simple for my wife.
Thank you all in advance for any assistance...
Solved by Techman
Create a favorite with a COMMAND type that runs the then statement in the program of your choice
The command would be to run the THEN statement of your program
Edited by Techman
Create a favorite
Click on EDIT FAVORITE
For TYPE select COMMAND
For DISPLAY NODE select the program you want to run
At the bottom in COMMANDS click on ADD, for COMMAND click on RUN THEN
Edited by Techman
12 minutes ago, Techman said:
Create a favorite
This is on Apple… When I click add command there are no options in the box to select Run If, Run Then…..
@drprm1
If you click on the ">" on the right side of "TODO get command nane (1)" do you see any additional options?
Hopefully someone who's using an Apple device can help you,
10 hours ago, DennisC said:
Try clicking the arrow where it says Set Enable. You need to change the command.
That’s what gets me to the empty command box shown here
I'm on Android and my screen is different. Try clicking on the help button (? in circle) left of the trash can along the top. See if the instructions are any help.
Help button only confirms what I’m doing.
There are no options in the Command box after trying to add command
After everything we did yesterday I was able to do what I couldn’t before…
(I’m using the version 1.3.4 not from TestFlight)
Thanks again
