October 26Oct 26 Is it possible to create a button in UD Mobile to execute the then statement in a program. I am running the Harmony plugin and have several streaming services on my home screen of the TV. I can go to my programs in UD Mobile and run the then sttement but I would like to make is simple for my wife. Thank you all in advance for any assistance...
October 26Oct 26 Solution Create a favorite with a COMMAND type that runs the then statement in the program of your choiceThe command would be to run the THEN statement of your program Edited October 26Oct 26 by Techman
October 26Oct 26 Create a favoriteClick on EDIT FAVORITEFor TYPE select COMMANDFor DISPLAY NODE select the program you want to runAt the bottom in COMMANDS click on ADD, for COMMAND click on RUN THEN Edited October 27Oct 27 by Techman
October 27Oct 27 @drprm1 My UD Mobile is running on an Android. Your screenshot looks different, are you on an Apple?
October 27Oct 27 12 minutes ago, Techman said:Create a favoriteClick on EDIT FAVORITEFor TYPE select COMMANDFor DISPLAY NODE select the program you want to runAt the bottom in COMMANDS click on ADD, for COMMAND click on RUN THENThis is on Apple… When I click add command there are no options in the box to select Run If, Run Then…..
October 27Oct 27 @drprm1 If you click on the ">" on the right side of "TODO get command nane (1)" do you see any additional options?Hopefully someone who's using an Apple device can help you,
October 27Oct 27 It’s just a drop down with True or False. Tried with both but still no choices in “Command” box.
October 27Oct 27 10 hours ago, DennisC said:Try clicking the arrow where it says Set Enable. You need to change the command.That’s what gets me to the empty command box shown here
October 27Oct 27 9 minutes ago, drprm1 said:That’s what gets me to the empty command box shown hereI'm on Android and my screen is different. Try clicking on the help button (? in circle) left of the trash can along the top. See if the instructions are any help.
October 27Oct 27 Help button only confirms what I’m doing. There are no options in the Command box after trying to add command
October 28Oct 28 I believe this is due to a bug in iOS Beta (test flight) version. Should be fixed in the next update.
October 28Oct 28 After everything we did yesterday I was able to do what I couldn’t before…(I’m using the version 1.3.4 not from TestFlight)Thanks again
