Posted Sunday at 06:59 PM2 days Is it possible to create a button in UD Mobile to execute the then statement in a program. I am running the Harmony plugin and have several streaming services on my home screen of the TV. I can go to my programs in UD Mobile and run the then sttement but I would like to make is simple for my wife. Thank you all in advance for any assistance...
Sunday at 08:08 PM1 day Solution Create a favorite with a COMMAND type that runs the then statement in the program of your choiceThe command would be to run the THEN statement of your program Edited Sunday at 08:23 PM1 day by Techman
Sunday at 11:55 PM1 day Create a favoriteClick on EDIT FAVORITEFor TYPE select COMMANDFor DISPLAY NODE select the program you want to runAt the bottom in COMMANDS click on ADD, for COMMAND click on RUN THEN Edited yesterday at 12:00 AM1 day by Techman
Yesterday at 12:00 AM1 day @drprm1 My UD Mobile is running on an Android. Your screenshot looks different, are you on an Apple?
Yesterday at 12:10 AM1 day 12 minutes ago, Techman said:Create a favoriteClick on EDIT FAVORITEFor TYPE select COMMANDFor DISPLAY NODE select the program you want to runAt the bottom in COMMANDS click on ADD, for COMMAND click on RUN THENThis is on Apple… When I click add command there are no options in the box to select Run If, Run Then…..
Yesterday at 12:23 AM1 day @drprm1 If you click on the ">" on the right side of "TODO get command nane (1)" do you see any additional options?Hopefully someone who's using an Apple device can help you,
Yesterday at 12:46 AM1 day It’s just a drop down with True or False. Tried with both but still no choices in “Command” box.
Yesterday at 01:49 AM1 day Try clicking the arrow where it says Set Enable. You need to change the command.
Yesterday at 11:52 AM1 day 10 hours ago, DennisC said:Try clicking the arrow where it says Set Enable. You need to change the command.That’s what gets me to the empty command box shown here
Yesterday at 12:03 PM1 day 9 minutes ago, drprm1 said:That’s what gets me to the empty command box shown hereI'm on Android and my screen is different. Try clicking on the help button (? in circle) left of the trash can along the top. See if the instructions are any help.
Yesterday at 12:15 PM1 day Help button only confirms what I’m doing. There are no options in the Command box after trying to add command
