October 29, 2025Oct 29 I am trying to run Flair nodeserver on Eisy/PG3. I have client_id and client_secret from Flair app, but not sure of exact syntax to enter into PG3 configuration screen.Can you provide some direction?Thanks.Maciek
October 29, 2025Oct 29 @MBrzeski you need to add custom variables in the configuration screen.From the More Info section: "Add a custom variable named host containing the client_id and client_secret. Those value need to be requested from Flair Support." Click on "Add Custom Parameter" and then the "Key" should be "client_id" and add another to be "client_secret". Then hit save changes and restart the plugin. Be sure you are not logged into Admin Console at the same time as installing/updating plugins. When admin console relaunches it will read/load any changes you made in the plugins.
November 22, 2025Nov 22 Author Thanks for the reply.I checked with Flair support and the credentials are now provided directly in the IOS app, which is what I have been using. Are there any delimiters required around the parameters (such as "SKJFKFKJFBEKFJ" or 'KSDFJFBSDFKJBFSDKJ') or just enter the raw parameter?
November 23, 2025Nov 23 @MBrzeski that I do not know. I don't use this but just tried to help with the steps to add the custom keys. Maybe somebody else uses this plugin or Flair support can help further.
November 25, 2025Nov 25 Author OK. Thanks for your help. I think that this may be an OAuth 1.0 vs 2.0 issue. Flair has moved their authentication to OAuth 2.0 and I suspect the nodeserver is still using OAuth 1.0. I don't know much about OAuth, just trying to get my vents working!
Tuesday at 06:00 PM3 days Does anyone have an update on this? I am experiencing the same issue and it looks like my OAuth 1.0 Client ID and Client Secret are no longer working, but the OAuth 2.0 authentication does not seem to be compatible with the Flair plugin.How can we get this plugin updated to work again?
