October 30Oct 30 I have upgraded to the new Alexa+ service (AI version of Alexa), and its now telling me the existing skill (ISY Optimized for Smart Home V3) will no longer be supported in a week. Every time I give Alexa a command for an ISY device, it executes it, but then says:"The skill for <device name> hasn't upgraded to support the latest version of Alexa. You will no longer be able to use this device with Alexa starting November 4th"How can we get an upgraded skill that is supported by Alexa+? I don't want to lose all my device control via Alexa. The only alternative is to unregister for Alexa+ and go back to the original Alexa experience.Apparently they have new SDKs for developing new AI compatible skills.https://developer.amazon.com/en-US/blogs/alexa/alexa-skills-kit/2025/02/new-alexa-announce-blog Edited October 30Oct 30 by BILJ Add a few clarifications and additional info about the new SDKs available.
October 31Oct 31 Solution What is being removed on November 1st is support for the Amazon Smart Home API V2. This used to be the case for our older "ISY Optimized for Smart Home V2" skill. The "ISY Optimized for Smart Home V3" skill uses the Amazon Smart Home API V3. This is still supported and the only current way to implement a Smart Home skill for Alexa.When using Alexa+, this still works with smart home skills. The new "AI-native SDK for Alexa+" allows to develop custom skills. I guess it could be used to control devices, just like the older Alexa custom skill API could do. But regardless, smart home skills using the V3 API is still the current way to develop smart home skills.Now, I have had many reports of users receiving the warning you mention. I do not know for sure why. I believe this may happen if you used to have the older ISY Optimized for Smart Home V2. Either it's still there (along with the V3 skill), or there's some remnants of the older devices existing in the account.In preparation, make sure the skill you are using is "ISY Optimized for Smart Home V3". On November 1st, if you see some devices are no longer responding, please do this:Login to the Alexa app, test the device there. If you see it is not working, delete it from the Alexa app.Ask "Alexa, discover my devices". This should recreate the device in your Alexa app based on the configuration you have on my.isy.io. If it doesn't, login to my.isy.io, look under Select tool | Connectivity | Alexa. Make sure that your device is there. If it is not, create it. It may be that device was created a long time ago using the V2 skill. With the V3 skill, the device discovery will create a V3 device in your Alexa account.
November 1Nov 1 when I added the V3 skill, I looked for the V2 skill to remove it and it was nowhere to be found. Perhaps there is a way to find it and remove it?and by the way; its actually "after November 4".
November 2Nov 2 Author Yes, I also had the V2 skill earlier and when I switched to V3 I always felt the V2 skill was still running but it was not listed in the app, and there seems to be no way to delete a skill. Having both active could explain other strange behaviors. I guess I will see what happens after Nov 4, hopefully it will continue working via the V3 skill, and I do appreciate the great writeup from bmercier with the tips.
November 2Nov 2 On 11/1/2025 at 10:36 AM, someguy said:and by the way; its actually "after November 4".I think the original annoucement was for Nov 1st, but then it was moved to Nov 4th.
November 3Nov 3 13 minutes ago, GHansen02 said:I have the ISY Optimized for Smart Home V2. How do I upgrade it to V3?You can follow the information in the wiki:https://wiki.universal-devices.com/ISY_Portal_Amazon_Echo_Integration_V3You'll want to disable/unlink the V2 skill first. Not a requirement, but might actually remove it from the Echo/Alexa "my skills" and not give you a warning about it not working soon.
Tuesday at 12:18 AM2 days @bmercier I just went through this at my daughters house. she was getting the no longer supported message when issueing commands. She was on V3 of the skill.It turned out ONE of her 5 echo's had the Alexa + skill , 4 did not but all responded with the message. removing it from the ONE made the message stop.In adddition, when the ONE was enabled, the Alexa App did not show skills, just alexa programs. Once removed, the App showed skills again.So... any alexa device on your account makes the skill anoying at best, useless at worst.I believe the newest Alexa devices only support Alexa +.does this mean ISY will not support the newer Devices, or will you look into supporting Alexa + ??
Tuesday at 05:53 AM2 days My wife is threatening divorce if I don't get Alexa to stop talking back to her when she's trying to simply turn off the lights.I removed the skill completely, deleted all devices from Alexa... And the re-enabled the v3 skill, and re-discovered all devices and scenes.Alexa still insists that the skill will stop working starting November 4th.At this rate - the marriage may survive Christmas... But 2026 may a be rough New Year if I have to choose between Alexa or my wife. Edited Tuesday at 05:54 AM2 days by MNicholes
Tuesday at 02:05 PM1 day @bgrubb1 @MNicholes I have no idea why Alexa talks back like that. If I understand correctly, this happens only if one of the echo is using Alexa+?
Tuesday at 03:43 PM1 day @bmercier that is correct. If any one or all are on Alexa + . As I said above, if you enable Alexa + on any unit, the alexa app no longer has a click box to show installed skills, It is replaced with "Alexa Programs"
Tuesday at 03:47 PM1 day @bmercier @MNicholes additional info - I had to go to each Alexa unit at daughters house and tell it to revert to old Alexa. Most of the units replyed with It couldnt perform the operation since they wer not the units that had Alexa + enabled. When I finall found the one that had it enabled it reverted. This my origional question. If you purchase a new unit that has Alexa + installed, you introduce the issue and I do not know it the newer units allow you to revert
Tuesday at 11:51 PM1 day I'd like to keep the alexa + capability but get rid of the sassy "... November 4..." responses. any suggestions?
14 hours ago14 hr bgrubb1, how do you tell if you have Alexa+, and if so how do you remove it to get back to ordinary Alexa?
14 hours ago14 hr you can go into the alexa app and see if you have a button for skills. If you dont you have alexa +go to each alexa device and say "Alexa, end early access"
