November 1, 2025Nov 1 Hi @Panda88 ,I think there is an issue with temp sensors suddenly on my system. This worked in previous versions. This is an old program I set up.I was checking to see why the program was not running. The program used to have temp of around -40F but not the program displays, well take a look at the pics. The second picture shows the actual values but at the top it doesnt.I looked in the logs and found some errors but they appear to be plugs that are disconnected right now.I tried restarting the plugin but it did not change.Thanks!Tim YolinkLocal_11-1-2025_15729_PM.zip
November 2, 2025Nov 2 I think there is a bug - somehow the unit is not changed even when I specify it - I will have a fix in the next release - it is something in the updated console program (my guess) that requires a different handling than before - there is also an issue with F and C they way I have handled in the past Are you really having temperatures down to -40f - I have that as a minimum for the temperature - do I need to support lower than -40 - Not sure the sensor works that low Yes - the outlet seems to be offline - press the set button -it usually fixes it
November 2, 2025Nov 2 Author 12 hours ago, Panda88 said:Are you really having temperatures down to -40f - I have that as a minimum for the temperature - do I need to support lower than -40 - Not sure the sensor works that low@Panda88 Lol, thank goodness, no. Back in the day, early on I was using this program as a heartbeat for the plugin so I selected the lowest temp possible. But now I see, at some point, you added Last Poll Time for the plugin which I have now switched over to use as the heartbeat (thank You). But when that program fired and alerted me the heartbeat was down is when I discovered that the temp nodes in programs were wacky.Thanks!-Tim
