remote access problem after power outage
I tried to connect to my ISY at work today via my iPhone and my connection timed out.
When I got home and was connected via WiFi everything was fine. I tried to again with 3g and nothing...
I hopped on my neighbors WiFi andI could connect to the ISY homescreen via my https://20.30.xxx.xx... but couldn't nagigate to any of the scenes, devices, programs, etc...
I saw some other threads about remote connection problems after a power outage so I reset my router and ISY...nothing.
Then I unplugged my cable modem and plugged it back in again and DING DING DING! Everything is working fine.
I guess my power went out last night during the storm? Is there anyway I can prevent from this happening again? Or is there another fix without manually resetting the cable modem?
Sorry if this has been covered before. I've read a lot of the forums before trying the cable modem reset and didn't see anything.
My ISY-99i software is up to date (2.7.15)
gtrotter4,
You can put the Router/Modem on a UPS. If that is all you are trying to keep powered there are small UPS devices which are not very expensive. I keep all my PC equipment on a UPS which includes a DSL Modem. Most of the time the phone line and DSL capability stay up even when power to the subdivision fails.
The only possible issue is that a UPS can easily interfere with Insteon communication, mainly due to signal attenuation. I use a SmartHome Filterlinc between the UPS and the powerline to prevent that. Just be sure things like the ISY PLM are not on the UPS or any surge suppressed outlet.
Lee
