July 29, 201016 yr still not working, manual on 2413 has no testing info, The isy seems to work ok but system does not send or receive any traffic. when I first noticed problem the lan lights on this port were not working. So lan port on isy may be bad or the 2413 is blown. any help would be helpfull on the reset/testing of the PLM/PLC Combiniation
July 29, 201016 yr Please call Smarthome and ask for a replacement. We will sort out which parts are bad later. Rand
July 30, 201016 yr Author Please call Smarthome and ask for a replacement. We will sort out which parts are bad later. Rand Thank you do you know if I use the back ups from the old to the new unit?
July 30, 201016 yr Yes. You will have to Restore ISY and Restore Modem (PLM). Rand Thank you do you know if I use the back ups from the old to the new unit?
