How do you determine if Zwave LR is actually LR
Hi. I have EISY w/Zwave-Zmatter dongle. Both are on most current firmware versions. I also have UD Mobile @ current. I'm long time Insteon user (150+devices) and am experimenting with Zwave. I gave up on Zmatter (too immature still) and have several Zoos 800 LR devices. I've included them. I'm disappointed in the range. I've moved dongle to less 'wall constrained' location (using USB 2.0 enable cable) to get it physically away from the EISY and associated other metal distractions.
The Zooz Zen04 800 LR acts like a non-LR device. Is there anyway to actually tell if it's included as LR. When I added it, I used the OCR method, on UD Mobile as it was recommended by others on the forum, but I'm questioning if it really included as LR.
Any quick methods to confirm ?
Thank you in advance Scott
5 hours ago, tlightne said:
The Zmatter/Zwave dongel does not support Zwave LR.
Thanks......I was referring to the below, which implies it supports LR....or is it that the currrent dongle doesnt yet support LR, but will....any insights ?
I am not very familiar with Z-Wave long range, but when I first added Z-Wave to my Insteon mix I had to use repeaters to get to more remote devices. As I have added more and more Z-Wave, the need has lessened.
8 hours ago, junkycosmos said:
Is there not a way to see if the device provisions as LR in the device zwave details ?
...that's what I was trying to determine. I've searched the Forums, asked the various AIs, but can't get a clean answer. This is my current configuration of the zwave device in question:
Hi all...in case it helps anyone, Michael was able to get back to me directly. The dongle is 700 based, not 800, so yes it's 'long range' but it's not 800 long range. Yes, that's a little confusing.
