Sunday at 11:55 AM4 days Hi @sjenkins ,I want to provide the configuration via a .yaml file but I'm not sure where to locate it on eisy so the plugin can find it. Looking through other threads, I saw this path mentioned:/var/polyglot/pg3/ns/<specific plugin directory>When I try to open that directory permission is denied. I tried stopping the plugin and using 'sudo', but I can't get access.If that is the correct location, how to I add the .yaml file?Thank you.
Sunday at 02:14 PM4 days Solution I have mine in the following location - which I believe is the default location when you login.
Sunday at 05:16 PM4 days # Store in /usr/home/admin/# No SSH required, Command to copy file FROM cd current directory (e.g., Mac desktop) to eisy# Replace with your own IP and user name and dev file namescp 2025-10-10-devfile.yaml admin@10.20.30.xxx:/usr/home/admin/
Sunday at 07:02 PM4 days @tmorse305 ,Looks like the team has you covered. Anywhere under your home directory. I made a dir for all my local test plugins which I keep these, but anywhere there is good. Thanks @jkmcfadden & @maxnorth !!
