Monday at 06:28 PM2 days Shot in dark. Did you just upgrade to 6.0 branch of FW? If so, it uses the portal credentials for authentication vs the local.
Monday at 06:43 PM2 days 4 minutes ago, Control74 said:I have the portal identification but i get access denied messageTry it on my.isy.io. They are the same.
Monday at 09:01 PM1 day 2 hours ago, Control74 said:Updated eisy firmware and can no longer loginWill you please provide more information? What firmware did you upgrade to? (give actual number, if known)Open this page in a browser: https://eisy.local:8443/WEB/sysconfig.txt (Click "Advanced" and "Proceed..." if you get any warnings)What versions do you see for:udx iox eisyui How are you trying to log in?eisy-uiadmin consoleIf you're trying to log into admin console with the IoX Launcher you'll need to manually add the local credentials address. Try adding "https://eisy.local:8443/desc" then using your previous local user/pass combo to login. If your IoX window shows the local IP without a port then you will need to use the email and password that it used to log into the UD Portal site (https://my.isy.io).If you're having issues with the web UI be sure to perform a page refresh and/or close the browser then open it again and hit refresh (or even hard refresh - varies depending on computer OS and browser).
